Early KitchenAid KDS-21: The Holy Grail Has Finally Been Found
Hey now!
Save some for the rest of us! LOL. I agree, I absolutely love the KDS-20. I always thought that it was the second best DW ever made, right after the KDS-21. I read on here that the 20 series had a redesigned drying system, which would explain why the dishes dry better than in the 18 series. I’ve also read that the vent location on the 18 series can contribute to rust in the corner of the lower rack if heated dry is used, which was fixed in the later models.
I’ve officially started working on the machine. I got all the itchy, mouse infested cotton candy removed and thrown away last night. I also got the majority of the glue that held said evil cotton candy to the tub scraped away as well. I spent about two hours cleaning it after these pictures were taken. What really amazes me is that all of the rubber is still flexible, and doesn’t appear to be deteriorated. The only deteriorating rubber I’ve seen so far is the seal around the detergent dispenser, which will be addressed in due time. I don’t know what kind of rubber was being used in these DWs, but it was top notch. So far, everything looks like it’s pretty much completely intact still, which I guess makes sense, given that it still works fine. The only issues that I’m aware of so far are the motor bearings, the detergent dispenser seal, dirt, and some surface rust. I plan to dismantle the entire machine to clean it, and check for any rust that needs to be treated. Since I’m going so far into it, I’m wondering if it would be worth adding a constant rinse arm to the top of the tub, and changing out the hold thermostats to ones from an 18 series machine, so that I can get hotter temperatures. I’m planning to run it again later today, and I’ve got some pretty bad dishes. Pictures will follow.
Thatwasherguy.
KitchenAid Superba dishwasher differences
Reply number 20, the KDS 20 dishwasher uses the same drying system as the 18,20,and 22 of the superb of dishwashers only the 19 had a different system, as it did not have a dry heater at all. It just had a fan to circulate air through the tub after it did a hot final rinse many users did not like this as well because it did not dry as thoroughly and they went back to the KDS 18 dry system on the suburban models for the next few models.
The KDS 20 is a much better performing dishwasher than the KDS 21 the 21 was cheapened to just one final rinse and had too many corrosion problems with racks pump, seals, etc., because the lack of rinsing away the caustic chlorinated phosphate detergent that were used in this time period.
Cleaning performance test KDS 21, the dishes with food on certainly came clean as they would
in any decent dishwasher. The flower vases are more of a mineral stain and probably no dishwasher would get that type of soil or stain off glassware without using an acid, which would not be good for the dishwasher, it’s also a bad idea to wash flower pots, etc. in dishwasher with sand and grit I’ve seen a number of dishwashers damaged by customers trying to wash flower pots in them.
John L
My KDS-19 still runs like a champ.
I had to re-seal some hose fittings a while back, but she runs fine now.
As for any rust showing up on the racks, I had a few spots that I sealed up with J-B Weld about 20 years ago, and that cured the issue permanantly.
I’ve got a little bit more done on the KDS-21 over the last couple of weeks. I dismantled the entire control panel, and cleaned all of the kitchen grease out of it. I also found some fake wood paneling at Menard’s that looks very close to 70’s woodgrain, so I cut panels from it for both my Sub Zero 550 and the KDS-21. I plan to start the disassembly process soon, so expect another thread over in the shoppers square forum detailing the parts that it’ll need.
Combo52…
That’s kind of what I was figuring. I didn’t think that those vases would come clean with regular DW detergent. I wouldn’t have thought about the dirt damaging things, but it makes sense. I certainly don’t plan to wash stuff like that in there on a regular basis, I just threw those in for fun.
phillymatt53…
I’m not surprised, everything I’ve seen so far with my 21 is extremely well thought out and service oriented. Thanks for the tip about the JB weld! I’ll put some of that under some Re-rack to fix any rust on the new racks. The old ones are way too far gone to fix that way, unfortunately.
Thanks,
Thatwasherguy.
    3.3 MB
    1.9 MB
That's incredible! As someone who's been hunting for a KDS-21 myself, I know how rare and revered they are. If you're planning a restore, I'd recommend checking vintage appliance forums or parts resellers—some gems still pop up there!
Welcome to the forum! Are you looking for a Whirlpool built KDS-21, or a Hobart built model? I’ve already found a set of racks from another member, I just need to pick them up at some point. I’ve also got a lead on a potential source of NOS parts locally. By the way, I actually saw another KDS-21 on marketplace yesterday. I’ll post it on a thread over in Shopper’s Square here directly.
Thanks,
Thatwasherguy.
In the 21 series KitchenAid dishwashers there’s virtually no difference between the ones that were built by Hobart or after whirlpool acquired the company except that the qualities is a little higher on the whirlpool ones
So you really shouldn’t be looking for one or the other you should be looking for the one in the best condition
John L
Hello- first time poster! I have a KitchenAid Custom 21 DW that we have been using for over 9 years. We recently returned from 3 months away and the machine makes a loud grinding noise during the wash cycle. It sounds like the motor needs replacing. Any advice on where to get a motor assembly? They all appear to be out of stock on the usual parts sites. Is replacing the motor do-able for someone who is quite handy but has never repaired a DW before? I'm located in the Philadelphia area. Thanks!
Take it apart down to the drain impeller, there's probably just an item caught in that area making a racket.
Combo52…
phillymatt53…
Thanks,
Thatwasherguy.
I just took a pair of R/F201 Sub-Zeros out of service, built in 1979 and still working well enough to use. How many other 45 year old fridges are still sitting in the kitchen? The final nail in the coffin was not being able to find a gasket for the freezer's door, even generic. Funny thing, I put a KDS-21 in a rental property in Maryland when it was new, cost me all of $400... Never occurred to me that I'd live long enough for one to become a classic!
My basic 14cf top freezer GE fridge is still working perfectly since 1985, so it's now 40 years old.
I do love the looks of the 21 series, but I'm so fussy that I couldn't abide by the single final rinse. Around 2011, I did get a KDC-20 portable. I initially had some issues, but a Finish Powerball broken in half in each dispenser fixed about 90% of the problems. I sold it when I moved in 2016. Now I realize that most of the problems stemmed from the banning of phosphates around the same time. If I come across another 20 series portable, I'll pick it up.
Welcome to the forum! I would advise using EBay for any parts you may need. I’ve been amazed at what I’ve been able to find for my machines there. In fact, I’ve actually already bought several of the parts for my KDS-21 project through there. If EBay doesn’t have them, the shoppers square forum here is a fantastic resource. I recently bought a discontinued pump that I couldn’t find on eBay off of another member for one of my washers. I can’t speak to the ease of removing the motor from this machine, as I haven’t gotten that far along on my machine yet. However, I’ve taken apart the door and control panel, and everything there is very service oriented, so I can’t imagine it being overly difficult. Let us know what you find!
My granny had an early 70’s Montgomery Ward chest freezer up until she moved in 2017. If the new owners didn’t junk it, it’s probably still working. My next door neighbors also have a Montgomery Ward freezer in their basement, an upright model from about 1981. It’s still going strong (and they now know who to call if they ever got rid of it). My great aunt had a late 60’s B.F. Goodrich upright freezer up until she died last year. As of my last visit in 2023, it was still working. As for refrigerators, I can think of a bunch working vintage units outside of my own; a 1953 G.E. two door at a local business, my neighbor across the street’s 1993 Amana top freezer, and my aunt’s 1994 Whirlpool side by side, my uncle’s 1995 magic chef top freezer, a 80’s G.E. top freezer at a pizza restaurant in Frankfort, and a early 90’s Frigidaire top freezer at a family friend’s business office, to name a few. I totally agree about appliances that seem modern becoming vintage. I remember when direct drives were being sold in big box stores, and when our 2006 Frigidaire stove was cutting edge technology. It’s funny to look at that stove and realize that it’s almost 20 years old.
I’m not surprised. I’ve been pleased with the build quality of anything G.E. from that era that I’ve come across.
The single final rinse is the only thing I really don’t like about the 21 series machines. I’ve been contemplating taking a timer meant for a KDS-20, and installing it in my 21 with a relay to allow it to work with the reversing motor, but I probably won’t bother. I’ll probably just do what Tom suggested, and add a small bucket of water to it whenever it goes into the post wash purge. Good luck with your search for another 20 series!
Thanks,
Thatwasherguy.
The pump and motor assembly just lift out of KD 18 and later KitchenAid dishwashers, they’re easy to service. They’re still plenty of parts around if you need them.
I have a pair of top-of-the-line KitchenAid refrigerator in freezer from 1987. Only part ever replaced was the lightbulb on the refrigerator.
There are companies that make replacement door gaskets if you need one of course the only reason a door gasket goes bad is because people don’t keep them clean and they spill sticky stuff and when they open the door, tears the gasket overtime.
John L
If I'm correct, my KDC-19 has a rinse before and after the main wash.
And at the end does a Sani Heat final rinse.
Start - Fill - Pause
Water heater -Sani heat
Pre-wash - drain
Fill - prewash drain
Fill - main wash - drain
Fill - rinse - drain
Pause - fill - Sani Heat
Final rinse - drain
Fan drier - then Off.
John L
Yep!
The only thing I ever replaced on my 1985 GE fridge was the lightbulb 20 years ago.
