Good Luck Eric! I had one of these for a while and it was fun to use. I remember ending up drenched after the first time I used the thing, but I caught on quickly.
This is the MOL model with one, rather than two, drain controls. To keep water in the spinner tub for soaking or softening, you twist the valve on the end of the drain faucet. Not really a disadvantage since the drain in the spinner has to be open for the rinse. You're in for a real treat, Eric, when you see an Easy do its rinsing. No other machine rinses this way.
This is the second Twinnie tihs season which the lovely L has scored for a member.
