Economy Size
mixfinder
May 1, 2006
4,581
Its incredible the savings on spices, flavorings, food color and staples like cake flour at restaurant supply. I was out of cake flour and parchment baking sheets so I made the trek. Softasilk cake flour $3.19 at Safeway. 50 pounds of Cake Flour at Cash and Carry, 17.49.
America's Test Kitchen
On their public television show ATK made the famous Tunnel of Fudge Cake. I decided to modify the recipe by replacing part of the sugar with Poly Dextrose and part of the flour with Resistance Starch and lower the caloric impact.
Warm and Soft
Cakes mix and perform better better when all the ingredients are at room temperature. I put the eggs in a bowl of warm water to temper them while I creamed the butter.
Tricks of the Trade
I have found that pulverizing granulated sugar in the blender cuts down on the time needed to cream and dissolve the sugar into the butter before addition of eggs.
Gently
Eggs create an emulsion and surround the sugar particles. Fully creaming the mixture before adding aggs one at a time adds more air and makes for a finer textured cake. If eggs are added too quickly it can cause the creamed mixture to "break" losing air. If cold eggs are added to the butter it causes the butter to solidify and again the air is lost.
The pictures are reversed for eggs and pulverized sugar
Time to be Quick
Once dry ingredients are added to creamed mixtures its imperative to work quickly. Over mixing can cause loss of air and volume, develop the gluten in the flour and make it tough In cases of leavening like soda and baking powder they begin to work as soon as they are activated by moisture. [this post was last edited: 6/2/2010-13:05]
Moisture is not your Friend
Moisture activates the leavening ingredients like soda or baking powder. The faster it gets to the oven the more "oven spring" or rise is created.
Gently, Gently
The creaming and proper mixing of cake batter incorporates air. I have seen bakers take the time to properly mix a cake and then bang the pan on the counter to get rid of any "air bubbles". Duh, that's what we want. Butter cakes don't get air pocket like an angel cake or foam imulsion.
Trust Your Timer
Tunnel of Fudge cake uses no leavening but air and is designed to have a gooey center. There's no way to test it for doneness. At 45 minutes the cake should be have a cracked top and be ready to take from the oven.
Cool Your Jets
The cake needs to cool for the starch to bond and the butter cool down enough to allow the cake to come out in one piece. Let it rest for 20 minutes.
I've heard that called a pudding cake-one that seems underdone in the middle almost like thickened batter? Sounds nice, because what I'd really prefer to some cake is a bowl of batter, but I don't like to get food poisoning!
The Gratifying Thud
The cake is inverted on a serving plate and in a perfect world you hear a soft thud as the cake lands in one piece on the cake plate.
Gilding the Lily
A simple glaze of melted chocolate, Karo syrup and cream is spread/drizzled over the cake. A few of the publications of America's test Kitchen including Cook's Magazine.
Cross Cultural Differences
Poly Dextrose replaces the texture and moisture of sugar in a batter sweetened with an artificial substitute. Resistance Starch is not digestable to it reduces the carbs and glycemic index in baked goods. Poly Dextrose makes batters more cake like and brown less. Here is the contrast in one recipe of Haystack Cupcakes made as written and one with Poly dextrose and Resistance Starch. The lighter and cakier cupcakes are with the replacements.
Already Gone
I cut a piece and was really happy at how gooey it is for mucking with the recipe. I gave it to a neighbor but he won't care if I go get a picture.
Poly Dextrose and High Resistance starch are available on life at Honeyville.com. I use a sugar replacement for sweetness and then replace 2/3 of the sugar in the recipe with Poly Dextrose. I replace 1/3 of the flour with High Resitance starch in most recipes.
Sneaked In and Snuck Out
Here's the fudgy center. It couldn't be more perfect and it's calorie foot print has benn mitigated to a small degree.
Kelly
did you add walnuts to the Tunnel of Fudge cake? The original recipe and I believe the revised / updated version mandates them.
At any rate; the cake looks delicious.
Are You Nuts?
The recipe calls for 2 cups chopped walnuts. Notes in the side line say the tunnels won't form unless the nuts are added. Powdered sugar and cocoa replace the original frosting mix and they're tossed with nuts and flour.
Looks scrumptious, as your baked goods always do, Kelly!
I shop at restaurant supply stores, too. The savings really add up if you do a lot of baking.
I'm also a big fan of America's Test Kitchen/Cook's Illustrated recipes. I have the Family Cookbook (like yours, above) and the Best Recipes tome. They are always my go-to references. I have Cook's Illustrated magazines going back---well, more years than I care to admit. Love their equipment tests as much as the recipes.
The only ATK recipe I didn't care for in the end is their cinnamon swirl bread. For one thing, the recipe is too large for a standard 9" x 5" bread pan (4-1/2 cups of flour), and the end product is just a little too heavy; more like a big slice of cinnamon roll than a classic cinnamon swirl bread. Otherwise, every recipe has been a 'keeper' for me.
Ella Rita Helfrich
of Texas entered her Tunnel of Fudge cake into the 1966 Pillsbury Bake-Off. Oddly enough, she did not win first prize. She did win a prize however, and a place in baking history.
Before this cake, the Bundt pan was a limited distribution item, mostly available in the Upper Midwest.
Yes, as Leslie alluded, the original recipe called for a powdered frosting mix, which is no longer in production. When I make a cake for frosting, I now always make a frosting from scratch. Packaged frosting mixes, except for Jiffy brand, have gone the way of the model T Ford. Pity, because even packaged frosting mix makes a better tasting frosting than canned frosting.
Looks wonderful (as usual!) Kelly.
Lawrence/Maytagbear
