The motor that I'm using for my rotary phase converter is used/old. I vibrates as the back housing that holds the rear bearing has bored out as the motor was originally used for a pump. It is 5 HP 230/460V 3PH 1800 RPM TEFC motor. The first motor is used and still have would work fine until it started to heat up. When this motor would heat up I my multimeter would read some very weird voltages coming from the three legs(1/2, 2/3, 1/3) and the voltage would be at times a little higher. My washing machine would react to the changes in voltage, for example, I would know when the motor was putting out weird voltages when the reversing timer in my washing machine would be out of sync with the cycle timer, and during the start of the extract cycle, the motor would sound louder and rushed. Voltages from one of the legs would be as high as 266V, and the other two would be around 238V and 244V. The phase imbalance would cause the motor in the washing machine to get hotter and after the cycle, I would smell the windings burning.
The motor that has the vibration issue provides voltages on the legs that are much more stable. I am currently using 2 line reactors that are connected in series to reduce the phase imbalance, so, my voltage average is about 233V and the volages that I get from the legs are 228V, 230V, and 232V. The washing machine likes this configuration a lot better. But, I still have the issue of the failing generator motor, I think I'm just going to have to fork over money and buy a new motor. They are a lot cheaper than a replacement motor for my washing machine. Maybe I will buy one for my birthday.
I was asking about reversing the transformer because I have a 460V 3ph motor that I would like to use for a project(maybe a washing machine) and the few step-up transformers on ebay are extremely expensive. I've seen some step-down transformers 460Vpri 3ph Delta/230Vsec 3ph Delta on there at prices that are within my reach.
Now for my next question:
Have you heard of a 3phase motor being used as a generator by itself? That is a 3phase motor in which the shaft is rotated to the nameplate RPM's by some other source and the leads of the motor being rotated are connceted to a machine to be powered. Is this possible?
The "Hot line tags": Are these used when the power company is doing maintenance to their substations or powerlines? When your company runs the 1.8MW generator, Does the some of the electricity from it go back into the powergrid? And if it does, does your company get paid for it?
