Electrolux frontloaders - reworked
Marketing.... Pure Marketing
More specifically Millenial marketing.
Because it's too difficult to toss the pod in the drum. One needs a college diploma to do that, so now people don't need to think, just toss the pod in the drawer.
In no time, detergent manufacturers will create a new technology, even "easier" to use, but unfortunately "a little bit" more expensive (just 25x the price).
The detergent will be a powder with a scoop in the box, then a second box with the pods. The user needs to carefully dose the powder detergent using the scoop, then use a scale to make sure the dose is accurate for each pod, then fill each of the the pods (10 pods if you have a large load, 4 pods for small loads). Then you place the pod in the dispenser drawer.
But don't worry, this new technology is much better than simply dosing the powder and pouring it in the dispenser. Because the dispenser has an exclusive place to put the pod and also because our grandparents used to do that, so, if it's different, it's obviously much better than jurassic things our grandparents did.
Ok, I'll bite.
It's not pure marketing, or to dazzle starry eyed Millennials
Here's why.
I don't use pods in my Maytag frontloader because A) they're expensive and stupid.
B)...and this is important....because the pods break up upon wet tumbling, and powder/chunks get all over the boot and under the glass, where "maybe" throughout the wash, water and clothes will swipe them away and into the drum.
This way, the pods can be dissolved, and used in Electrolux's special water/soap mixing chamber, and then sprayed uniformly over the clothes.
John, there should be somethign really wrong with your washer or with the way you're loading it.
Start by tossing the pod in the drum (it will fall on the back) then load the washer.
It just needs a few drops of waterto start dissolving, and they dissolve really fast.
Once i made a test using a fabric softener cap and some water. It dissolved completely, with no agitation at all, in less than 30 seconds.
Pod being trapped on the door boot, eventually if you load the washer and then toss the pod over the load and near the door.
Anyway, pods are really stupid. IDK why some people love them.
I used pods/pacs exclusively for a couple of years and loved them. Simple, easy, convenient, cleaned well. They dissolved properly in my 2010 Frigidaire front-loader, as water began entering the tub as soon as tumbling began. On a couple of occasions a pod migrated to the boot before being fully dissolved. I thought--and still do--that pods will increase their market share in the future. Look how they've taken over in automatic dishwashing.
The only reason I went back to liquids is because my 2015 Maytag had an auto-dosing system that was even more convenient. My decidedly non-HE Speed Queen top-loader would probably need two pods for large loads, which would get pretty spendy. Never had to use more than one in the FrigiLux front-loader.
The pod dispenser in new Electrolux front-loaders is a great idea. It eliminates the possibility of staining (if the pod gets trapped in the center of a large load) or winding up partially dissolved in the boot.
Only Pods in my stash currently
Which have powder are those "booster" stain release pods from Tide. Mainly oxygen bleach and other things.
In any event at least in the AEG Oko-Lavamat yes, the darn thing most often gets caught in the boot leaving powder on glass, and or in same.
Sometimes after five or so minutes all is dissolved and dispersed; other times not.
Think issue is many front loaders use so little water that pods with any sort of powder just cannot dissolve properly.
The instruction manual (downloadable) seems to quite informative, which is a good thing, but...
...it appears that this is another of these 'no filter access' machines!
Bloody daft idea. Lint can and does get shed by items. It can accumulate and block the pumps - even those which have a pre-strainer, as the odd loose thread or fibre can still make its way through the strainer allowing the 'worm' to grow as is accretes particulates. Sooner or later, a clogged recirculation or drain hose will likely occur. I recently had to unblock the spray jet manifold on my Panasonic machine, as one of the three outlets was clogged with cotton lint. Frequently (monthly), the pump filter has the same debris which obviously does make its way through the pump filter.
I would say from experience, that the older Zanussi method of recirculation was probably the best: a decent sized filter, with a decent diameter of hose leading to one outlet only. This minimised blockages and was easy to clear. Whether this Electrolux employs anything similar is anyone's guess.
Thomas and GELaundry, you're missing the point.
Yes the physical activity of throwing a pod into a hole is very easy.
But on many machines, the pod parts and powder get all over the boot before it's fully dissolved. Not all front loaders have spray jets that wash down the boot and window.
ALSO, do you guys know that Electrolux has a feature that pre-mixes the detergent prior to injecting the solution into the wash?
Throwing in tabs negates that feature.
So Elux devised a solution to allow laundry tab use, while still using the water/detergent pre-mixing feature.
my toughs and my 2 cent here
if you notice here in Canada most he detergent for washers are liquid detergents you rarely see powder laundry dertengents these days since on store shelves they mostly focus on liquid laundry detergent or pods and the brand of washing machine mention in this thread might be Electrolux but not all brand of washing machine are the same gelaundry4ever next time you enter an appliance store if you see en Electrolux washing machine open up the dispenser drawer and compare it with a brand like whirlpool or maytag and you will see a big difference.
They are actually excellent washers...
I worked for electrolux and I can make a list with 1 thousand reasons to hate the brand, but I have to be fair and admit they are very decent washers.
One thing we've all learned here... If the CR ratings are poor, the product is great. If the ratings are great, the product is usually an Eco-Nazi  POS.
Gee that's funny, everybody on here wants to bash the new speed queen in the name of " consumer reports" and when i say otherwise i get attacked. But whe i say something in the name of consumer reports it gets dismissed 🤣🤣 i agree with you though. Consumer reports does not like anything american.
Electrolux is swedish... LOL
But with the speed queen, no, the washer is a POS, PERIOD.
No, I'm not a purist, I am a designer, I love innovation, i love modern washers... and Yes, I HATE that speed queen model. I like the company a lot, i admire the previous models... but that specific model is the worst washer ever made.
And for me brands are not like football teams or religions.... I don't have a favorite brand, I now hate electrolux and above you saw me defending one of their washers because it's true, that washer is good. It's nof fantastic, it's not the best thing in the world, but it's not a POS like the 2018 Speed Queen.
Al you people are biased thats why. All you do is nothing but complain about everything. Electrolux is a piece of junk. Period. Just a rebadged frigidaire. The most unreliable poorly built front loaders on the market. Imported crap.
