Great responses!
I had a feeling that this would be a spirited thread!
First of all, I have been a proponent of the convection recirculation system for years having read about it in some magazine way back. My uncle always had problems with his dishwasher filling with "cooled" water as all his water lines in the unheated basement were uninsulated 3/4 brass pipes. His machine was probably no more than 25 feet from the hot water heater but he has alot of heat loss when the weather got cooler. I suggested that he try running a return line one size smaller(1/2") with a check valve to the bottom of the water heater by teeing off the drain valve and having the water run back to the heater that way.
I cannot tell you how amazed he was at how well this worked for them, not only in the kitchen but also in the bathroom on the first floor and to the apartment upstairs. The results in the dishwasher were so much better as well.
I was going to install the same thing in my house in Valley Stream, NY to get the water to the kitchen hotter faster instead of running the water before starting the dishwasher, but we wound up moving to Florida before I started that project.
Now that we are down here, our master bath is more than 70 feet away from the electric water heater and takes nearly 5 minutes of running the shower to get it hot enough to get in.
At 2.5 gpm, that is a waste of nearly 13 gallons of water for every shower per person. It sure adds up fast. Less time is required for the main shower and about 5 seconds for the bathroom shower in the garage which is right next to the heater.
All in all it can add up fast. In addition, whatever our water consumption is, we are charged a slightly higher rate for sewage on the water consumed.
I had considered the installation of a 6 gallon 115 v heater next to the dishwasher but that would not solve the major waste of water which is just the running of it to the far reaches of the house as well as wasting the water at the kitchen sink for the DW. So now we wash all the other non DW items so that the water is already hot and then turn on the dishwasher. But given some of the longer washes, the water can still run cold and fill the unit with cooler water than needed.
When we first moved down here, I was going to buy the Grundfoss circulation system with the remote controlled pump with the buttons in remote locations like the kitchen and main bath but never got around to it.I liked that system because it was On Demand and would be less wasteful. But they are now very expensive and the Watts unit goes for 199.00 at HD.
I will probably spring for it shortly as the colder weather is now here and already the water is being run longer prior to showers.
Man, I would love to get another water bill with even more reduced consumption like after installing the LG FL machine. 3000 gals less a month! Wow!
I will keep you posted for sure.
