English electric pump
lancethecook
Aug 28, 2010
166
Driffield England
Hi all, thought I would update you on the pump trouble just in case any of you get a similar problem.
Very difficult to describe but basically once the pump is in place a screw is tightened against it to hold it in place and adjust it's position. This screw also by pressure alone holds the cover on the pump so my struggle to open the pump was in vain , infact it only needed priseing open. The impeller had simply worn away it's grip on the central metal rod.
It's now fixed and I will put it back on the machine later.
Thanks to all who offered advice.
If anyone wants a photo let me know and I will post one.
Lance
