Evaluating the Westy
turquoisedude
Aug 8, 2007
10,588
Despite temperatures hovering just above the freezing point on the weekend, I was out in the garage tinkering with the latest find. I was keen to find out if the timer motor was indeed dead and alas, this is the case. It's packed up and will be sent to Midwest Timer tonight - I just hope they can find a replacement motor or even fix the old one. The gears can still be turned manually, which I hope is a good thing!
I hooked up a temporary power cord and found much to my delight the main drive motor runs perfectly! Manually advancing the timer made the fill and pump solenoids engage; but I think the spin solenoid blew the fuse...
I found that the flexible drive shaft for the pump was badly damaged in transit (literally bent out of shape). I hope I can fix or replace that!
And I noticed a potential tub leak problem here...
I think the machine died during a wash cycle and then sat there for a number of years judgin by the water scale accumulation in the tub. Looks like standing water residue to me...
Next steps
I took the changer off the tub mount and found much to my amazement that there was not a drop of oil in it. I am praying to the gods of automatic washers that putting oil back in it will make it turn because it is stiff as a board now!
I am also going to need to figure out how to take the inner wash tub out to clean and patch the outer tub. That should be an adventure!!
I am maybe being overly optimistic that I can get this machine back into service by the end of the year...
Good luck on the restoration. I actually don't think the westinghouse is too hard to work on, but getting parts is the challenge. I'd keep your eye peeled for another westy, I've picked up a few mostly for parts, then your worries are over.
have had good luck with cleaning the rust spots down to metal and then either POR or marine epoxy. looks like your gettin there one step at a time.. all will work out just fine in the end
