<span style="font-family: 'comic sans ms', sans-serif;">I've started to dig into the Westy Roll-Out. It's my first time with an Impeller machine in the roll out style.</span>
<ul>
<li><span style="font-family: 'comic sans ms', sans-serif;">First issue: The drawer will not stay closed. I found out there should be a tab by the line switch that the latch goes behind and that keeps the drawer closed while it engages the Line Switch and allows the machine to run. At first I thought it had broken off but then I noticed the line switch looks like it had been removed, the piece with the tab removed and the line switch put back on. Not sure what that is about but I have IM's the seller asking if they have it.</span></li>
<li><span style="font-family: 'comic sans ms', sans-serif;">Second issue: And I know this sounds odd but for the life of me <span style="font-size: 14pt;">I cannot find where to attach the power cord</span>. I have the service manual but it refers to the installation instructions which I do not have. I have photographed the Fill Valve set up which I believe I can put together as it in the manual. It all appears to be there. But where the heck does the power cord go? I've looked everywhere.</span></li>
<li><span style="font-family: 'comic sans ms', sans-serif;">I have applied power to the Fill Valve and it sounds like it's working. It also isn't nearly as dirty as the rest of the parts under there so I suspect it's been replaced at some point. I'm told this house has been closed up since 1975 and nothing was used but that the power was on and the machine did run through a cycle but the water is turned off.</span></li>
<li><span style="font-family: 'comic sans ms', sans-serif;">I've noticed water stains all around the top so I suspect it has been leading from there. According to the SM there is an adjustment to make it tighter. I will investigate. The tub seal at the top is also soft and supple with no visible cracks.</span></li>
<li><span style="font-family: 'comic sans ms', sans-serif;">The other issue though is around the pump. I appears as though that has been leaking. Is there any chance I would ever find a replacement for that?</span></li>
<li><span style="font-family: 'comic sans ms', sans-serif;">There isn't a single crack in any hose and they are all pretty supple.</span></li>
</ul>
<span style="font-family: 'comic sans ms', sans-serif;">So, I don't plan to make this a daily driver but it would be fun to use from time to time. Any help and opinions with this are appreciated. Thank you!!</span>
