cfz2882
time to remove some pounds for vanity reasons-starting to get the machines all oiled up and ready-current machines are:
-1970s Schwinn"fanbike"-this is the old twin chain gold painted style.
-1993 DP fanbike-decent, but not commercial grade like the Schwinn-uses a small chain that I have had to replace a few times.
-2007 Kettler ergocoach LS rower-recently got this one in damaged condition,plastic housing broken-rest looks ok.Uses "eddy current"drag on copper-rimmed iron flywheel,if I can't get the electronics working will have to hook variable power supply to the drag coil to provide resistance.This machine is made in Germany
I have found these machines and others quite effective if you stay with the program
