Faulty Motor ?
no Low Speed Motor Operation
Hi John, Yes Bud is likely correct, try his tests.
This is the problem trying to figure out failures on line, this is actually a fairly common problem on AWs with multi-speed motors, I am used to diagnosing things in person.
Usually when this happens the motor sounds strange, it only continues to run for a minute or two, the cord on the washer starts to get warm.
We had a KA washer do this on Saturday that we were working on in the shop, in our case it turned out to be the timer.
You could probably disconnect the low speed wires and tie them together with the hi speed wires and keep using the washer without the low speed feature which would not be very important to me for example.
John L.
Hey Bud and John L, thanks very much for the extremely helpful advice. I will try the tests and let you know how I get on. John, something you said there has came to my attention. The motor is actually making more noise than it should.
Hey everyone. Managed to get a new motor for my washer. Already wired up and it is running great, like it should do. Thanks everyone for their help. Much appreciated.
Johnny.
Glad they helped you
I've learned to do something through the years - whenever people present me with multiple potential solutions to a problem I'm having (usually with a FilterFlo), I print out all their suggestions, seal them in a zip-lock bag and tape them to the back of the washer. All too often (these machines are all well over 40 years old), another similar problem arises soon enough and hey, presto!, I've already gotten advice on it.
