Faulty New Wave :(
newwave1
Jul 20, 2005
1,982
Lincoln, United Kingdom
Hey Guys,
Well as the title would suggest, My hoover newwave has gone faulty.
It started lastweek, i went to do my whites and i started the machine, it started with the initial fill to shut off the eco valve, it normally clicks around for a minute then continues the fill however it didn't. Then, it tumbled straight away without any water. So i stopped it as i was running short of time.
So i went back to it today. I ran a rinse cycle, it showed -6 which indicates its on the 1st rinse. it filled, tumble straight away (which it isn't meant too) then it did the normal distribution drain. then disaster it didnt spin, the display changed to -1 which is drain. it kept draining and draining and wouldn't shut off. No error codes came up though?! I'm baffled by this one.
Anyone help me before i discard it. Im out of work and short on cash right now. So this made me even more fed up.
Darren
Possibly.......
Hi Darren
Im thinking there could be a fault on the pressure system that is telling it its full when its not- it could just be a blockage what model is it??
Seamus
Hmm but it fills up fine on the rinse seamus! Its a WN146
Proper confusing. What about the aborting the prog and not shutting off when it drained? It didn't come up with an error code either:S
