Hey guys I recently picked this up for 150, it’s a Hoover 0321, the pump and the motor and the ringer work well the heater has been disconnected but the main issue that I want to fix is the sump to tub hose is perished, I did test it before I brought it and it seemed to only be a little bit of a drip
So I bought it, brought it home filled it up with straight hot water from the hot water system which is probably over 60°C/140°F and there is quite a bit of a leak
What are you guys think I can do to fix this because I’m thinking it probably would be a good idea to replace the hose
