Favorite Dryer Design?
maytagneptune
May 7, 2017
196
FireAlarmTechGuy4444 on YouTube. Interlochen MI
What is your favorite Design. Mine personally is the Front filter Whirlpool 27"/DOTT Dryer. The 29"/top filter dryer is my least favorite. It simply takes too long to dry in my opinion even If I clean the screen after each use. My second favorite is the maytag Halo of heat design and the maytag SOH design. Feel free to state your opinion. I hate how many of the 29" units have no medium automatic cycle or have the wrinkle guard. the wrinkle guard on the automatic cycle every time makes the dryer take 2 1/2 hours to dry a load of clothes. my LG DLE5977W takes about 45 minutes.
Whirlpool duet quad baffle design is my favorite. Quiet and fast.
Fisher paykel smart load is my second favorite..
Though, the Neptune dryer 99’ series is a beast!
Any older Whirlpool or Kenmore built 29” dryer before 1966 in gas with the 37,000 btu heat output. Even if my 1963 Whirlpool Imperial dryer is electric, it gets quite hot since the glass window is quite hot to the touch in operation when drying towels.
I too must say that the WPMT quad baffle dryer is the best I’ve ever used. Quick. Quiet. And dries mostly uniform compared to others I’ve used. The quad baffles are perfect for tumbling small loads that ride the drum of every other dryer.
I have the Elux dryer now. I’m NOT a fan. It’s slow. Doesn’t fully dry most of the time despite cycle times around 60min for almost everything. The giant filter ledge is constantly getting clothes and socks stuck on it in anything smaller than a full load. I have to use a “helper towel” now.
It’s really sad sad Elux saddled their awesome washer with such a crappy dryer.
My 1963 RCA Whirlpool Imperial dryer is my first Whirlpool built 29” dryer I’ve owned and so far it hasn’t let me down in terms of drying performance. Very versatile in temperature options and never has damaged anything I’ve ever dried in it. I’d say it’s even more gentle with the speed bump style of baffles and there’s hardly any lint on the lint screen after I dry a load of laundry in it. One of the best dryers I’ve owned so far.
Oddly enough, I have used or owned nearly all the machines mentioned above.
My current Duet dryer has the quad baffle design, and I love it. However, I do find that it runs warmer and takes a touch longer than our older 29" top filter Kenmore. I loved the SoftHeat feature. My grandparents had a 29" front filter machine that was easily the biggest dryer I have ever used. All that extra space was great for even temperature and airflow. This is something the smaller Duet lacks.
Personally, I do not like LG dryers as they tend to have very hot normal cycles, and really underdry on the casual cycle.
my lg/kenmore dryer
does a great on the normal cycle. I've used heavy-duty to dry a full load of blue clothes and jeans, only to find my jeans started to shrink. I use the normal cycle with medium heat for 41 minutes on normal without energy-saver. I find its hot enough to get things evenly dry, and will shorten or lengthen time depending on the size of the load and moisture content.
We loved our 1970's Frigidaire 1-18 dryer. It wasn't a moisture sensor type, but the much maligned thermostatic type, but it worked perfectly. The wide-mouth door made loading and unloading a breeze, as did the tub light. It did a great job with bedding and other large items and it kept wrinkling to a minimum.
My favorite dryer is the Whirlpool 29 inch top filter dryers.
These dryers are hands down the simplest and easiest to repair while being some of the fastest drying machines in existence. Considering how simple they are yet how well they do their intended function Whirlpool's 29ich dryers are truly perfected engineering marvels. All other dryers just seem unnecessary complex and clunky by comparison.
Also of note is that the heat source is not directly behind the clothes.
I think my least favourite dryer design was the Hotpoint Reversomatic by mum had, which was a "pair" for with her X2000 washing machine. It had the heating element at the front, covered by a half doughnut shaped metal panel the width of the plastic drum, and the diameter of the porthole was a fair bit smaller than todays 600 mm wide machines. So I often burnt my arm on the extremely hot panel, checking if the washing was dry, and pulling the filter out, which was at the back, without leaving it long enough to go cold.
It also had the two worst, over complicated button latch mechanisms I've ever come across, one for selecting half heat and the other to enable a buzzer that would sound after it had finished and at the end of each extra crease care tumble. For some reason, rather than sourcing a simple push button with its own built in latching mechanism, they used momentary action rocker switches, that spring back to the off position, mounted in a rear panel, with metal stalks riveted to the front of the "on" half of the plastic rocker, and with the plastic button and a pin attached to the other end. And each had a thin brass plate with a slot pattern cut through to latch onto the pin. The slots would get closed up with use, so I'd often be taking the front facia of the control panel off and using a screwdriver to open up the slots.
The element was a length of thin wire attached to thin asbestos string, a bit like the outer section of a spiderweb, when it broke it would short to the case.
One thing going for the design, was the fan at the back drew the room air into the metal cabinet which was sealed up with putty and foam draft strip, so being under positive pressure, you would never get any lint escaping into the case or element.
The tumble dryer I have now, was one of the hotpoint / Indesit ones that were recalled as a fire risk (about 11 years of production), after Whirlpool purchased indesit, due to the risk of fluff getting trapped in the rear foam seal and falling onto the element. Before that, I'd pulled one and a half large black dustbin bag fulls of fluff out of the case when I'd replaced the rear drum bushing.
Compact vented electric dryers that can be wall-mounted above a top loader; y'know the ones that sort of look like a small front loader washing machine?
These were the most common where I live before condenser and heat pump dryers were introduced, and you can still get them at most stores. Just about all of them on sale now have sensors, except the absolute cheapest dryers.
Most laundry rooms in homes are quite small here, so having a dryer that doesn't take up floor space is a big bonus imo
