hippiedoll
thank you:
for your replies.
beekeyknee:
as for the stop ring, i didn't take the stop ring off, when i cleaned the agitator shaft. i didn't know i was supposed to take the stop ring off & clean underneath it too, since i didn't do that with the 208 or the 608.
as for the splined hole in the agitator, i did clean that out with a toothbrush. and even when the vaseline was gobbing out, when i would put the agitator onto the shaft, i ended up wiping all the vaseline out of the splined agitator hole, with q-tips. so that is nice & clean now.
DigAPony:
i've cleaned out all the vaseline from the agitator hole & splines. and i now removed the stop ring and cleaned the groove where the stop rings fits into, with a wire-brush and some dawn dish soap.
also, the agitator doesn't have a set-screw on the side. i also placed the agitator down onto the shaft, while the stop ring is off, and the agitator went down all the way, with no problem. so i think you are right, the problem is the stop ring may have swelled up.
i also noticed 2 cracks running along the top edge of the stop ring too. i could see the cracks, when i was squeezing the stop ring.
lamont:
when i put the agitator back onto the shaft, i will remember to apply a "thin coating" to both surfaces & wiggle the agitator slightly as i'm pushing it down onto the shaft.
update:
since i have the stop ring off the agitator shaft right now & noticed 2 cracks along the top edge of the stop ring, i have decided to buy a new stop ring on ebay and put the new stop ring on the machine and throw away the old stop ring. this the stop ring seems to be the problem.
i will remember to lightly grease the agitator shaft & the groove for the stop ring, before putting the new stop ring on. and then, i will put the agitator on. should i put some vaseline on the stop ring too, once i've got it into position on the agitator shaft, so that the agitator will slide over the stop ring easily?
THANK YOU GUYS SOOOO MUCH FOR YOUR REPLIES. without you guys, i would still be scratching my head, wondering why i can't get the agitator to pop on & off easily!!!
LOL.....
now i know the culprit is most likely the darned stop ring!!
i'll keep you all posted, when i get the new stop ring in the mail. and i'll check back often to see if there are anymore replies with suggestions of what to do.
again, THANK YOU GUYS.
for your replies.
beekeyknee:
DigAPony:
lamont:
update:
LOL.....
