Yes unclejohn, I finally picked up my first Hoover twin tub!
Back in the end of August, Launderess posted in Thread #42001 a TT 0519 for sale in NY state. It wasn't long that I was in communication with the seller, and after two months, I finally drove 4 1/2 hours today to go pick it up (and 4 1/2 hours back). It just BARELY fit in my car, even after I measured to make sure. No problems at customs bringing it across into Canada.
First problem that it has is no back cover. The seller told me that it had not been used very much, and by the looks of it, I believe him. But he said a couple of years ago he tried to get it going again after it had sat for a while, and I guess misplaced the cover. He is going to let me know if he finds it, so there might be hope of reuniting it with the rest of the cabinet.
Bringing it into the house revealed the second problem... pump seized (no belt either, or so I thought). I was able to get it to turn without too much effort though. I also noticed that the belt for the spinner was partially off, so I rolled it back on the pulley and it seems to be okay. Inside the wash tub he had placed the owners manual and fill hose, but when I looked inside, I found a small belt that looked more like a vacuum cleaner belt than anything, but as luck would have it, it fit perfectly onto the spin motor pulley and pump pulley. Problem is that turning the spinner manually doesn't spin the pump pulley, so I don't know if the force of the motor would be enough to turn the pump, or if it would just slip the belt. Should I try the hot water down the pipes test and see if that helps free up the pump some more?
But other than the pump, it seems to be in really good shape. Both motors run fine (tested spin motor before replacing pump belt), and timer works. I didn't realize that the 0519 had an electric brake on the spinner... I thought that all of the Hoover TTs were mechanical brakes. I haven't tried any water tests to see if there are any leaks... can't see any cracked hoses, and I'm hoping that the seals are okay. Nice harvest gold cabinet with some fading and paint chipping off of the covers, but no rust.
Haven't had time to take any pictures, but I will post some eventually. I am heading out of the country for a week's holidays starting on Friday, so there probably won't be any pics until after I get back.
