Finally Royalty Enters My Home!
vintagekitchen
Aug 28, 2011
706
No, not some of our dear Launderess's Royal Doulton with the hand painted periwinkles, but vintage NIB Royal Chef cookware! As some of you guys probably remember, I had another thread trying to decide on a new cookware, and when I ran across a set of vintage cookware NIB, with the hard to find white Teflon II, I couldnt resist! Unfortunately the box itself was water damaged, so the seller asked if it would be ok to send the cookware in a different box, but with the original packing materials, and I quickly agreed.
Here are a couple of pics..
Love that white interior! I dont know why they ever chose to stop producing the lovely white teflon, and switch to black.
Discolored..
That would explain why the booklet mentions how to deal with stains, and says to either use Dip-It, or to mix baking soda water and bleach and simmer in the pan until the stain is removed.
The set is very attractive,I like the white Teflon.
is it Teflon or the Teflon II?
One thing the cookware looks to be kinda thin like the Foley and Mirro cookware my gram has rom the late 70s
Lawrence --- I used it for dinner tonight, and I can say I truly like it. I had forgotten how easy it is to cook in teflon! The "teflon scare" was really getting rolling around the time I moved into my first apartment, so I had never bought teflon for myself. Since then they have decided it is safe so long as it isnt overheated empty, so I felt ok buying this set. I have never owned pans so easy to clean, and I simmered my marinara sauce in it tonight for 2 hours with not the least bit of sticking. The bottoms are perfectly flat, and it responds very well to heat changes in my corning smooth top, much faster than my old set, which was so thick that between it's retained heat and the stove's retained heat it was difficult to lower the heat without removing the pan from the burner.
Sam --- It is the Teflon II, though I'm not sure what the difference between Teflon and Teflon II is.
The cookware isn't very thick at all. It's not as thin as mirro, more the thickness of the old West Bend stuff, but it tapers to nothing at the top edge, instead of the thick cut off edge West Bend had.
Tom and Harley --- I hope that so long as I follow the directions in the booklet, (and I have so far. When it arrived I washed it and conditioned the interior with oil per the directions.), I wont have any trouble with staining. One has to wonder how many housewives of times past actually bothered to read the instructions with the cookware, and follow the stain removal steps at the first sign of discoloration. Considering how much cookware I have seen with layers of built up baked on grease from people never cleaning the outside properly, and then complaining that it is impossible to remove when they finally attempt to remove it, not many. I would guess most pulled it out of the box, and immidiately started using it without conditioning it per the instructions, then didnt bother to do any stain removal until it had went past slight discoloration all the way to deep stains. Few people seem to grasp that maintaining a finish is far easier than restoring it, or even understand the difference.
Slightly off subject, but I guess my preferences are a bit odd compared to most. Most people say that the smooth top stoves are impossible to keep clean, but after I finally got mine clean the first time, it has been a breeze to keep it spotless. A quick wipe with the Weimans smooth top cleaner, and it is perfect, much easier than all the palaver of removing drip pans and reflector rings and such and soaking and scrubbing with a regular electric stove. So I guess that may account for why I like this cookware so much. Everyone is different.
Here is a picture of the box, before it was opened for shipping to me.
Teflon scare!!
LOL!! I also love aluminum cookware which some are still scared of, despite the fact aluminum is in practically everything we eat,and has been in such things as baking powder and anti perspirant for many many years! im not afraid of Teflon or aluminum, as with any cookware I dont store food in it or let acid foods stay in it for extended periods, nor do I overheat Teflon....but I don't overheat any cookware, and I agree, lots of people cook in NASTY cookware, it does not take long to clean the outside as well as the inside!!
Aluminum..
That was another bit of ridiculessness. The media took the fact that people with alzheimers had elevated aluminum levels in their brains, and have been terrifying people with it ever snce. When shortly after that first discovery, they found that it was not high aluminum intake casing alzheimers, but in reality, that alzheimers caused the high aluminum levels, the media decided to keep quiet, because it wouldnt be as interesting as terrifying people.
I have never been afraid of aluminum, I had a set of Club cookware, and the deep well pot of the GE stove was aluminum, as is my double boiler and cake decorator set. What I dont like about uncoated aluminum is that it is reactive with acid foods, so it can cause a metallic taste in some foods, and unless aluminum is kept scoured to a brilliant shine it can cause discoloration in other foods. So that reduces the amount of foods I can cook in the pans, as well as meaning I have to work harder to keep it shiny bright.
I also prefer glass bakeware over aluminum, as did my mother, and for the same reason. Glass bakeware lasts forever unless you drop and break it. Aluminum bakeware is paper thin, and after a few years, starts to develop pinholes, (especially if you keep it scoured shiny bright. Each scouring wears away a tiny bit of the aluminum). Also, glass cake pans mean never having to worry that the cake will have a hard or over-browned crust.
Aluminum...
My father lived to see 83 years of age, and was sharp and with it to the end. Aluminum cookware was used at home - the Club Aluminum Dutch oven was used for tons of chili, Swiss steak, stews...I still have the piece, and use it without fear (though I shy away from cooking anything tomato based in it). It is pitted, from use, and as mentioned, I keep it shiny.
Not to hijack this thread, but I was wondering - any further luck in lessening the stains on your new smooth top?
Joe
Cooktop stains..
At the moment the back 2 burners are perfect, except for a slight mark that looks like a rust mark, about 1/8 inch wide and 2 inches long, on the rear left burner, but it is fading. The front 2 burners are almost stain free, the front left has the faintest hint of a shadow, and the front right has an obvious pale gray shadow.
After my experience with bleach yellowing the melmac plates I was attempting to clean, I was loathe to try it, lol. Luckily, the stains have been lightening more and more with each time I clean the stove. (As I said, I clean the stove after each and every use, so it gets cleaned at least once or twice per day, every day). I am planning another treatment with the toilet bowl cleaner soon, and between that and the continued fading, I do beleive the stove will be perfect soon.
Hey Kevin,
We just sold a Regal roaster with a brown Teflon II interior, and the instructions are the same pre-first use; wash and oil. They also tell how to remove stains with a commercial Teflon stain remover or baking soda, water, and bleach.
Enjoy!
Chuck
The stove and the stains
Just finished cleaning up from dinner, and as you can see, the old girl is looking 100% better than when she first arrived.
Does anyone remember the remake of The Great Gatsby starring Robert Redford in 1974? With all of the 1920s summer costumes with white this and white that, there was a big tie in with the white Teflon, especially in Nordic Ware's Bundt pans. There were store displays featuring the film and the new color of Teflon.
