Fisher & Paykel Top Loading Gas Dryer Wires
pumper
Jan 2, 2009
318
SE Wisconsin
Does anyone have one of these dryers? It's about 4 years old. I took it apart to clean it out and I'm not sure about the reconnection of these wires. I know one end of the green one attaches to the bottom of the front panel, but I don't remember where the other end connected to. I think maybe one of those tabs on the bottom of the cabinet, but not sure. Also, the thick green wire..does that connect to one of the tabs on the bottom also? It seems to run properly otherwise.
I'm not home at the moment to have a look at my machine but both of those ground wires should reasonably connect to the tabs on the base.  Doesn't matter which of the three wires connect to which of the four tabs, just so they're all connected.
The screw that anchors the brown motor board housing to the lower rail is also an important grounding point.
