Hi,
This is a Frigidaire FWT645RHS, but this is a model-neutral issue/question. There seems to be a consensus that a good amount of blame for the failure of the ubiquitous aluminum spiders in these FL machines is due to excessive moisture retention. All of the threads related to this always have the advice "leave the front and dispenser doors open when not in use", etc.
So here's the question: has anyone done/considered adding a 'vent' to the top of the tub and employing some sort of forced ventilation between uses w/ a duct fan, etc?
Of course the end of the duct/fan would need to be high enough above the tub to avoid splashing, etc. Would that be much better than placing the end of a 6" flexible duct w/ a duct fan into the spin basket between washes?
I'm replacing bearings due to a failed seal. This is my 2nd basket, replaced maybe 5 years ago. Should have replaced the seal back then, didn't.
This spider has some pitting/corrosion, but is far from ready to fail, in better shape than anything on ebay right now. I'd like to make it last as long as possible. Don't think the stainless 1/4" bolts will ever come out at this point, so removal to prime/paint/etc is probably not an option. Love to hear any experiences re: venting. Thanks.
