Fitted Sheets from the Laundry Managers view
I process some 200 fitted sheets each day,And have ALWAYS HATED them. The Ironer must be run at half speed or less and the folder must be bypassed as they cannot be messured properly for automatic folding. It takes 5 people to run fitted sheets. 2 feeding the ironer and 3 folders. Two folding length wise as they come off a 375 degree ironer and 1 making the final 3 crossfolds. We can run 400 to 500 flat sheets with only 3 people in the time it takes to run only 200 fitted.
Fitted sheets DO NOT last as long as flat sheets as the elastic cannot withstand ironing temperatures and the detergents normally used in hospital or hotel laundring. on the avg. A flat sheets last thru 200 washings a fitted sheet will last approx. 75 to 80 washings. This is also not to mention the fact that too many times they are litterly "ripped " off the beds by housekeeping. Then we have the extra repair cost to add in also. We have several Drs. that have stock in 2 VERY upscale hotels here. And we have to process work for both of them also.. One uses fitted sheets the other does not. Both charge in excess of $500.00 per night. I assure you the cost of a room has NOTHING to do with the use of fitted sheets..
In 30+ years I have NEVER talked with any laundry manager that likes fitted sheets. We have to process what is purchased or wanted by others.
Most of the time the use of them is dictated by Housekeepers who are pushed into trying to produce more work faster, or see how many more beds can be made useing fitted sheets than use of flat sheets.
We still have a few that know how to make a hospital bed but too many times they do not want to take the extra few seconds it takes to do the job right. We also have one facility that knots the sheets at both ends making sure they will not come off the beds.
In the past years most fitted sheets would fit any bed. no so any more as mattress thickness are now VERY different. Now they range anywhere from 3 to 4" all the way to 9 or 10 " no one sheet will fit all anymore. Even in hospitals the thickness varies greatly.. This is also another point for flat sheets. as the thickness does not matter as much.
