Seems to be hard to find a trustworthy hose (or anything else for that matter) in today's market. Used to be you could buy a Gates or other top quality hose and it would last nearly forever. Today most of these hoses are made in China and sold without any sort of brand name. I always think if the company isn't proud enough to put their name on it I'm not interested.
The other confusion is the stainless braid silliness. Hoses seldom fail in the middle of the run unless they are cut somehow. The stainless braid doesn't make the end joints more solid. Its just like modern appliances, being covered in stainless doesn't make them better then non-stainless units, but it sure sells! Air hoses normally carry more pressure then water supply hoses, yet they never have a stainless over braid.
I have used both Watts and Fluidmaster hoses and they seem to be made well. Those red and blue Floodcheck hoses look pretty good too but boy are they proud ($$) of them, I suppose the significant extra cost helps cover the warranty. The FSP hoses always seemed just fine to me. I just replaced the set that came with the 1981 Whirlpool a few years ago and they were still fine. Do new machines still come with replacement hoses?
John's advice on the flow preventer 'safety' devices is sound, a failure is generally a leak not a blowout, at least at first. They are more likely to cause problems then prevent floods. Choose decent hoses, install them carefully, don't twist or strain them and inspect them frequently. If you are going to be away for a period of time, shut off the water. If I was dealing with a cabin or Summer home you can bet the main water would be shut off when I leave it.
