Food mixer recommendations
liberatordeluxe
Feb 15, 2012
530
UK
Looking for a replacement food mixer and after some genuine feedback on anyone who owns a Kenwood or KitchenAid machine. Which do they prefer and is a better overall make and longevity?
Failing those makes i had looked into a Magimix which i am pleased to see are made in France and not China!
I have a 1970s Kenwood Chef which I just love. It belonged to my Grandmother before me. It still has the cloth cover with the embroidered strawberries on it that she had. It seems bulletproof, and strong despite having only a 300 watt motor. Its only problem is it is very noisy, normal for ones of that era. I use it on a folded tea-towel to minimize noise and vibration on the benchtop.
Having said that, about 2 or 3 years ago I bought a little Braun Multimix for when I wanted something quick and easy instead of heaving the big Kenwood out. It was on clearance at the time, I think about $30 when they had been $120?
I think it is great, in fact since I got it, I haven't used the Kenwood at all...
At work (I was a cook for nearly 30 years, in my last 15 years I made cakes most work days) I used a slightly newer Kenwood Chef, it was very robust again and made great cakes. It got tired after being thrashed for over a decade, we replaced it with a similar looking Breville, which proved unreliable - it would strip a gear when making my carrot cake mixture. It did that several times. The Kenwood made hundreds without issue. We briefly used a Kitchen Aid and I quite liked it, but it was very noisy and didn't offer anything the Kenwood didn't offer.
My big advice is that the slowest speed is probably more important than the highest speed. You want a machine with a well-controlled (governed) very slow speed, capable of combining dry ingredients without throwing them around your kitchen. Many cheap machines don't go slow enough for this task, they fling your ingredients on the walls and on you, so you have to combine by hand with a spoon before using the mixer. The old Kenwoods like my Nan's have an internal adjustment for the governor, you can adjust it to turn really s-l-o-w in little bursts, it's great for that initial combining of ingredients. Try to get a test run before you buy. The little Braun goes nice and slow on its lowest setting.
https://www.catch.com.au/product/braun-multimix-3-hand-mixer-368133/
used Kenwood
Hi, you being in the UK I would prefer a used Kenwood, either the 701 series, 901 series or newer 201 etc. There are rebuilding services in UK who basically return you a brand new robust machine if you do run into breakdowns. One of the online repair/rebuilding services sells complete mixers as well, they even repaint housings to your choice of custom colour. A possible eventual problem of running on a single speed is easily repaired with a new varactor resistor kit but my collection of used machines has not revealed that problem yet after a number of years and I have examples of all three above models. I just made the 9 1/2 cup of flour Ukrainian Babka Easter bread recipe last week in my 201 without problems-just don't exceed speed 2 when kneading bread dough. When the charity thrift store has a unit with bowl and all three attachments for $10 Cdn. or half-price day of $8. what's to resist buying?
Are you sure the Magimix is still French made? My cookexpert comes from PRC, just like the Kenwoods do now. I’ve got a range of Kenwoods from 1950 onwards and I use my cooking chef as a daily. As Chris said, the low speed is what’s most important and I find the fold in function on the kenwood works a treat. I’m not sure whether it’s still the case, but the Kbeater in the kenwood will be stainless steel, where I believe the kitchen aid will be coated and not necessarily dishwasher safe.
If you only mix small batches, don’t get a Major/XXL machine, the whisk is a huge chunk of wire and it won’t successfully whip 2 egg whites. It does great with 14 egg whites, but for small batches I use a Chef instead.
Someone from the US will be best placed to answer, but do the kitchenaids have any really low speed fold type options or is it just a minimum stirring speed?
Making cakes for a very long time ....
I have always preferred a Kenwood as you got a slow start thus not showering flour everywhere. Magimix I find awkward as its starts too quickly and just chucks the contents out.
I have to concur with above statement of buying a 2nd hand one the Chef Major being a bit bigger in total than normal chef may be more use to you and they do indeed have a lot of spare parts floating about online so always easy fixed. I recall back in the early 90's when I cooked a lot I had an older pale blue model that had the liquidiser cut off when the plate was removed to use the Jug it stopped the beaters going round now the part of the cover had worn over the years causing the mixer to stall and judder I cured the issue with a Biro it was the right size to push in the hole and connect the gears I just took the biro out when not needing the mixer it worked for years like that....
Depends on your needs.
A local ice cream shop which makes homemade using liquid nitrogen uses comercial Kitchen Aid's with slow start and the power cords are orange.
@ozzie908 I had the Kenwood Chef with liquidiser attachment and i reckon it must of been over 40 years old when it packed up. Had lots of use and i probably will replace it with either a Kenwood Chef or Kenwood Kmix. I currently just use my Kenwood Kmix hand mixer which is brilliant and does all the basic stuff so meets my needs so far.
I doubt id use a food processor much at all so food mixer would be a better buy.
