Miltrol
When I cut a chart for a nursing home or anywhere where I know pads/diapers will be processed.....I will cut is as follows;
on a 5 compartment supply system, the operator would load it as the situation(formula)called for. when using automatic supplies, the chemical company will control the supplies on their end when the operator selects the correct formula on the chemical controler
in the following example; there are 4 temperature switches;
hot/cold/thermo 1/thermo 2
thermo 1 and 2 are just what we know as Auto temp control, and can be adjusted at any time to be whatever you want them to be. When any temp is set to "in" that tells the machine to "use" that temp, versus what's called for on the chart
below, I set thermo #1 to be 110 degrees for controled rinses, I could set thermo #2 to be 95 degrees to override the chart when washing personals, colors or blankets and spreads
each can be commanded "off" "in"...which is "on" or "formula"....which means follow the chart
2 min/ flush/ split/ high level - start point for pads
1 min drain
2 min/ flush/ thermo 1/ high level -
1 min drain
6 mins/ break/ hot/ low level/flush supply #1, alk- start point for other heavy soil work
1 min drain
8 min/ suds/ hot/ low level/flush supply #2, soap- start point for medium soil work
1 min drain
8 min/bleach suds/ hot/low level/flush supply #2, soap and #3, bleach- start point for light soil work, bleach bath for normal work, carry over for non-bleach work
1 min drain
2 min/ rinse/hot/ high level
1 min drain
1 min intermediate extract
2 min/ rinse/ thermo 1/ high level
1 min drain
4 min/finish/ thermo 2/ low level/flush supply #3, sour and #4, soft or blue or starch or iron out or anti-clor or a combo of them
1 min drain
7 min final extract
any step can be lengthened by moving the master switch to manual or shortened by advancing the chart
