jcturbot
Active member
While recently checking the wattage usage on my Bosch Nexxt Washer I not only saw my wattage go to almost 1100 watts used on the Hot water wash but was surprised to see that I had about 225 watts used on all three rinses. The Bosch uses a cold only rinse.
After checking the rinse temp in the water dispenser the cold water coming into the Washer was 42-44 degrees.
Now I know with Automatic Temp Control used on today"s machines the Wash temp is regulated but what about the rinse temperature?
With those with a Heater and a Kill A Watt meter be willing to check out their machines to see if the Heater is engaging on the Rinse cycle.
Jeff
Jeff
