FOUND! Ironrite "95"
Think About Using An Ironrite And Or Other Rotary Ironers
Is to learn just how damp laundry is supposed to be.
Too moist and you have to send things through multiple times to dry.
Too dry and ironing results are poor and one risks scorching things.
Unlike other ironers the Ironrite does not have a speed control. So the only way to deal with areas that are too wet is to constantly start and stop the roller with the knee controls. This "pressing" will help get things ironed dry.
I had success in using a non flameable brake cleaner from an auto supply story when I cleaned out the gearbox in my Ironrite. I just took out the drain plug, put a pie pan under the drain and then sprayed in the cleaner. I also used a small stiff brush to loosen the old gummed up oil along with the cleaner.
Another thought on the dampening. It may have been mentioned here before and I recall my mom talking about it. Once you dampen the clothes, put them in a plastic bag and then put the bag in the refrigerator. I think it keeps the clothes from souring or mildewing, if you don't get to your ironing quickly. You'll find if the clothes are too damp they'll stick to the roller.
Depending jpon time of year and climate in your location, leaving damp items laying about waiting for ironing, even in plastic can cause disaster. That is mould and or mildew stains, which by the way are nearly impossible to remove totally if severe.
Yes, placing items in the fridge does by some time, but not long as one thinks. Remember foods go mouldy whilst sitting in there as will damp laundry sitting in a sealed plastic bag.
Personally find it better to take items from either the extractor (spin dryer) of the Hoover TT or "Spin-X", or out of the Miele and they are nearly always near or ready "damp dry for ironing". There are some things that one does not extract too long or even at all. These are allowed to drip dry but not until they are totally dry. Just enough moisture remains in some areas that once folded and allowed to sit for a bit will evenly distribute all over.
Oh and another thing, though common house-keeping lore suggest rolling items up tight after dampening, it is not always best. Better to fold things carefully best to allow moisture to evenly spread out. Also the smoother you keep things before ironing the less work there is to do,regardless if it is by machine or hand.
L.
