Throttle down!
Jon, I have often removed the flow valve in the valve itself but you do need to throttle down the water because if your water pressure is high it can really fill the machine so fast it will push a wave out the right corner or the left side if your machine has the fill gap opening right behind the top left rack track. Also, the machine will fill right up to the max amount allowed by the float switch and it will be right under the lip of the door.
If you happen to open the door and then close it and turn the machine right back on, it will probably flood out the door and on to the floor. So I usually turn it down and adjust it at one of the purge fills so that it comes up to nearly a full fill level. That way, when it fills normally, it will come up to a slightly higher level or at least to the float level and stop.
You really have to go by trial and error and see how it works for you.
The other thing is to replace the valve itself completely with another one that fills at a faster rate.
Once again, Combo52 John may be able to supply those specs from som of the many machines he works on.
I guess one other option would be if you have a spare float assembly, cut the stem just a but and it will shut off a bit sooner and then you may not have to worry about the really high fill level. Again, trial and error.
