Found on Craigslits
Where do you get that stuff?
You can but it separately (204999), but it also comes with a glide and spring kit (205000) which I would recommend if you haven't replaced those items yet.
Hmmmmm
Machine worked perfectly before the application of WD-40.
After application, wash motion was slow.
Tried to wipe some off with rubbing alcohol.
This morning's wash action was ok with no clothes, slow with clothes. Perhaps I need to replace the belts.
Got the belt today
Kit came with two belts, rollers and springs.
Put on the new belts.....agitation still slow.
Called the appliance repair store. Told me the tension was off(worked fine when the motor was pulled back). Told me an old trick years ago was to stretch one of the springs onto the grey frame. Should make the agitation good again. Tried that and it worked perfectly. This weekend, will try to change the springs.
