electric can openers
Wow, I am surprised so many people don't use an electric can opener. I thought virtually everyone did.
I have a GE Spacemaker (original from the eighties) that mounts under the edge of the cabinet. It is right there at the perfect height, always ready, and it doesn't take up any counter space. Almost everytime I see one a a thrift store, I buy it. So I have a little collection of them in case my ever goes bad.
Juicer?? Never used one, never will. Fruit is too expensive to get the juice out of it then throw the rest of it away as pulp.
George Foreman Grill--yes. I am single so I use the small George Foreman Grill everytime I make a hamburger. It's easy to clean and doesn't spatter grease or pop grease like I usually do in a skillet. It's small enough, that after I wipe it off it fits in a drawer. It cooks faster, and more evenly, than a skillet, too as it cooks both sides simultaneously.
220 volts would be nice, in that you need only have the current (amps) for the same amount of work at 110 volts. volts x amps = watts Hence smaller guage wires can be used.
Down side--danger. You almost have to try to electrocute yourself at 110v, its much easier to do at 220. However, as I always tell my students VOLT'S DON'T KILL, AMPS DO! But for a given resistance, a higher voltage will allow a greater current (amps) to pass through a conductor. When that conductor is the human body, higher volts will make it easier to pass a lethal current through you.
I OFTEN use the analogy of a knife. With the size of the blade representing amperage and the force (or push) on the knife being the voltage.
You can have a great big knife (= high amperage), but if you put it up to your chest and barely push it (= low voltage), nothing happens. Other than you might feel a tiny little prick of the point where it touches you.
You take the same knife and put a tremendous push behind it...well you get the picture.
By the same token, take short little fine needle (=very low amps) and push it with great (=high voltage force), and you might get a slight sting but no real damage.
That's why a Vandegraff generator or a Whimhurst maachine, with thousands of volts, with not hurt you, but only give you a tingle. There is not enough current present to electrocute.
Voltage is electrical "force" and current (or amperage) is the "amount" of electricity, i.e. the number of moving electrons.
So, I think in the U.S. we do it right by not having higher voltages for normal household appliances. Safety is number one. As many people do dumb things, we don't need 220 volts to increase the odds of bad things happening to them, when they do.
Even though 110 volts is relatively safe, people still sometimes manage to do things to kill themself. Can you imagine if that was 220 coming out of the outlets!!
