Reply #17
You can use the rinse and spin but that's a preselected water level
So…. You don’t know that most if not all washers are now Auto Temperature Controlled?The only thing that drives me crazy about the new Whirlpool/Maytag washers is that people do not under stand that Cold water is 67-72F when laundry manufacturers and detergent companies mention it. if you are in the northern states and Canada our water is colder than that on the hottest day of summer. It cuts the life of all the new top loads in half. When you see a detergent commercial that says "we are Canadian, we KNOW cold water", throw your shoe at the TV. If you are in the northern half of the US or further North, NEVER use a temp setting colder than Warm and you will have a washer pump and transmission system that works perfectly for 10-12 years. If you insist on tap cold water it will be dead in 4-5 years. Also there is an issue with that washer in the first post due to Panasonic making a bad batch of electronic board thru-hole pressure sensors. Then they discontinued them so there is a back order on all the Whirlpool WTW4850, WTW4855, Amana NTW4519 and Maytag MVW4500 and MVW4505 control boards. As a retailer and servicer, I miss the serviceability of the older machines, but we can still fix most boards as long as the electronic parts are available and the manufacturers have not covered them in "waterproof" epoxy.
I prefer a deep rinse. Today's spray rinses don't work as well.Yes Mark, you may choose an extra rinse if desired.
Eddie
Can you go into details, why Cold Water will cut the lifetime of a washer? You stay it shortens the pump and the transmission? First time I ever heard this.The only thing that drives me crazy about the new Whirlpool/Maytag washers is that people do not under stand that Cold water is 67-72F when laundry manufacturers and detergent companies mention it. if you are in the northern states and Canada our water is colder than that on the hottest day of summer. It cuts the life of all the new top loads in half. When you see a detergent commercial that says "we are Canadian, we KNOW cold water", throw your shoe at the TV. If you are in the northern half of the US or further North, NEVER use a temp setting colder than Warm and you will have a washer pump and transmission system that works perfectly for 10-12 years. If you insist on tap cold water it will be dead in 4-5 years. Also there is an issue with that washer in the first post due to Panasonic making a bad batch of electronic board thru-hole pressure sensors. Then they discontinued them so there is a back order on all the Whirlpool WTW4850, WTW4855, Amana NTW4519 and Maytag MVW4500 and MVW4505 control boards. As a retailer and servicer, I miss the serviceability of the older machines, but we can still fix most boards as long as the electronic parts are available and the manufacturers have not covered them in "waterproof" epoxy.
This is not actually true.So…. You don’t know that most if not all washers are now Auto Temperature Controlled?
If you’re local water is too cold, the ATC will adjust to add hot water so your “cold water wash” is at least 65deg F so detergent can work best.
TAP COLD is the setting that will get you the temp of whatever comes to your house.
If you’re so concerned just don’t ever use TAP COLD.
It does it in several ways. Cold water causes Grease and oils to thicken. All of the more efficient washing machines use smaller lower power motors with transmissions that are more heavily geared. When the grease thickens, it causes the motors to work harder, pulling more electric current, and cause issues with the electronic control boards primarily in the relays. Also, detergent does not dissolve well in cold water so there is more residue build up with in the machines, sometimes causing excessive corrosion to portions of the transmission/ agitator shafts which can cause seal failure. Also, what you are primarily trying to remove from clothing is body grease and oil. Think of it like a roasting pan when you cook a turkey. Do you wash it in cold water? of course not. The grease would congeal and be twice as hard to remove. In a cold water wash, the grease and body oil congeals and does not get broken down as well with the new enzyme based detergents because in cold water they freeze up and do not work. You end up with more residue, more build up and eventually more corrosion. This was the downfall of many a Front loader as well, Especially the Maytag Neptune.Can you go into details, why Cold Water will cut the lifetime of a washer? You stay it shortens the pump and the transmission? First time I ever heard this.
