Frigidaire Dishwasher OrbitClean Spray Arm Issue
Status Update
The new, OEM, OrbitClean arm has been working flawlessly nearly two months later. Although I could have held onto the conventional, dark blue spray arm and used that, I ended up returning it, unopened, a week later. Since I pre-rinse all dishes, it does not matter what type of spray arm a dishwasher has. To me, a DW is more of a dish sanitizer.
Fortunately, this arm does have metal on the bottom of the orbital end. This reduces the chances of the plastic melting if it comes into contact with the heating element.
I checked online, and around late 2020, Frigidaire produced a dishwasher that features TWO OrbitClean arms. In addition to the lower one, the middle arm has an orbital end. In my mind, this translates to another part that can potentially fail, in addition to the lower arm.
Even today, Frigidaire makes ONE model that still has the orbital arm. I, too, am baffled as to why appliances have "goofy" designs which don't work that great in reality.
While it’s certainly not the best design, it’s easy to see why they make the orbit clean arm it cleans better, especially in the corners
Reply number 41 the fact that your pre-rinsing dishes proves you don’t know how to use a dishwasher, start putting the dishes in dirty, use the high temp wash option, add a little bit of liquid or powder detergent on the door in addition to a high-quality pod in the dispenser and this Frigidaire dishwasher will get everything spotlessly clean without pre-rinsing.
Like any piece of mechanical equipment you have to learn to use it to the best advantage so that it suits your needs.
John L
finish ultimate
Well, I've been using Finish Ultimate since late 2023 and I've found they've done better than Cascade in my dishwasher. They're bigger than the quantum tabs. At least that's what I've noticed. They do leave a pleasant scent behind.
Do you believe they are better than Quantum tabs. I been using them since last year as BJs switch from carrying Finish Powerpods to them.
