Chad---I had several Frigidaire DWs from 2000-05. All were the TOL models. (I change dishwashers frequently, just for the hell of it.) I found they did a great job with 'normal' loads; dishes, cutlery, glassware, glass/Pyrex casseroles. Crusty pots and pan, not so great. I always gave them a prelimiary scrubbing before washing. I really liked having the 1/2-load option which would wash either the top or bottom rack alone, using about 3-1/2 gallons of water. The Aqua-Surge gimmick was fun to play with, too. I generally always used the highest spray force setting, but sometimes, when I wanted it very quiet in the kitchen, I'd set it at the lowest setting, which cut the noise of the machine in half. Normal or lightly-soiled dishes would still come clean. It only runs at half-power for part of the cycle, anyway.
Now that I have a Maytag, which has a more powerful water spray, I wouldn't go back to Frigidaire. Loading is more flexible, pots and pans don't need a pre-scrubbing. It isn't as quiet as a Bosch---neither are the Frigidaires---but it isn't noisy, either.
