niclonnic
I've had this washer and dryer set for a couple months now; it came with my new house and I'm finally getting around to making a post about it.
Right off the bat, I was glad to go back to a good old top-load washer with an agitator, as I honestly feel that this type of washer is more effective than a front-loader, particularly my old LG which used very minimal water.
This machine is a lot more basic than my last one. It features a stainless steel tub. The agitator simply tosses the clothes around with no turnover whatsoever. It tends to be rough on towels; at the end of a cycle, I occasionally see towels that come out a bit ripped, leading me to cut off the loose fibers with a pair of scissors.
The noise emitted during operation is weird, but at least the machine is quieter than older top-load washers, especially my previous Maytag Atlantis TL washer used in the old house prior to the LG. Is this a thing with current TL agitator washers?
There's also no option for the water level; instead, this machine senses how much water to use depending on the load size. That feature works really well.
The lid is locked during the entire cycle, so the detergent, clothes and any additives must be added prior to starting the machine. Fortunately, the washer can be paused mid-cycle to add any forgotten clothes.
One interesting option is "fabric softener." Turning that setting on changes rinses to deep, filled ones.
One downfall of the machine is the water temperature. Whenever it's set to HOT, the water doesn't actually get that hot; rather it's LUKEWARM at best. So it doesn't truly sanitize clothes. Does the lid allow a lot of heat to escape?
I don't have much to say about the dryer; it's an electric dryer, and it gets the job done. However, the "delicates" cycle doesn't fully dry clothes.
Notwithstanding some faults, I do enjoy this washer and dryer set quite a bit. I feel that my clothes come out cleaner than they did in my LG FL washer. What are your thoughts on this set?
