Frigidaire Flair Removal
sprog
Jul 18, 2019
74
Boston
Well, I'm about to do it again. I've found a Frigidaire Flair (30" single oven). It's begging to become yet another in my growing appliance collection. I can't resist that MCM vibe it exudes.
I would be responsible for removal. Are there any tricks or pitfalls I should be aware of? I'd hate to accidentally trigger a hidden self-destruct mechanism. Any advice would be greatly appreciated (John, Paul?).
By the way, Paul, how is your Fair working out?
Sincerely,
Chris a.k.a. Sprog
Removing a 30 inch flare
It should just be sitting there but they are heavy you will need at least two strong people to move it.
It may either be plugged in or directly wired in, inside the cabinet below it that needs to be disconnected so the power cable does not impede the removal of the range, in some cases you need to pull the range forward a foot or so and disconnect the wiring if it’s hardwired.
Good luck
Thanks John!
As always, your insight is greatly appreciated. I'll report on my progress.
Thanks again,
Chris
Frigidaire flare ranges
Are not a fire hazard and meet current safety standards you’ll notice the front burners are set in so there’s still more than 6 inches from side walls when pulled out if it’s installed in a corner.
And the rear burners have metal sides to protect any adjacent woodwork or walls from the excess heat if an element is left on High with no pan on it.
John L
Be sure
To check inside the cabinet as the installation directions required securing the range to the cabinet. There should be a bolt from underneath in each corner. This keeps the "top-heavy" unit from tipping forward when installed. Also, if you plan to move the range on its back or side, be sure to tie down the door and tape down the burners so they don't pop up and jam the drawer.
Good points Steve, I have yet to ever see a flare that was screwed down but I had forgotten that they actually did ask you to do so it was probably more for mobile homes that move as there’s no way that unit would ever tip forward lol even if you stood on the front edge of the cooktop with it extended.
In general you are going to be best to leave the unit upright to move it otherwise try to tape or tie the door down but the springs are very strong and that when you turn it on its side the door does not wanna stay closed.
John L
Chris - you'll want at least two people for this move. These are very heavy units. You may also want to remove the drip pans and burner supports before moving (depending on how it will be transported). I moved a 40" double oven Flair (heaviest stove I've ever moved) and we had to lay it on it's back to get it in the van. The drip pans and burner supports got loose and it took me a while to be able to pull open the cooktop. This is not a concern if it's going to remain upright throughout the move.
Good luck!
Not sure about that
I can get my Flair to tip forward by pressing down on the front edge of the burner drawer, and it's screwed to the base cabinet. I don't think I'll attempt standing on it.
Thanks guys
I appreciate the wisdom.
Steve, I'll look underneath for the anchoring bolts (hopefully absent).
I'll bring my son (collegiate rower).
As per usual, leather gloves, a full tool kit, impact driver, duct tape and a dolly.
Nice one Kenny...
This should be an adventure!
Chris
