58limited
I picked this up today to use as a beer fridge - it will hold 4 (or more) of my 5 gal. soda kegs. I plan to run taps through the door.
The reason the previous owner got rid of it is because of a water problem: water drips from the freezer into the fridge compartment. I do not know much about auto defrost fridges. It appears that the drain tube that goes from the freezer compartment into the lower refrigerator compartment is clear of blockages - water drains down to the tray mounted in back on the top of the compressor. I think the water is coming from two 1" square holes in a block mounted to the top of the fridge compartment (not sure of terminology). The water that drains from the freezer comes into this block and is directed out the back through a drain tube, but it overflows and drips out of the two holes. How do I fix this problem? It seems to me that there is too much water flowing through the system, maybe there is another problem. The door gaskets are in good shape and appear to seal perfectly.
Also, are there any cooling coils on the sides of these fridges? I need to drill a hole to run a CO2 line to pressurize the kegs.
Does anyone know the year this model was made?
Thanks and Happy Holidays everyone.
