maytagneptune
I picked up this set today from a used appliance store, Models GLTF1670AS1/GLEQ642AS2. Dryer is electric. Serial for both states February 2006. The washer's bearings are shot so I am going to disassemble the washer tomorrow. Hopefully the spider shaft isn't too damaged, Otherwise I am going to need a donor machine or apply a cheap temporary fix using waterproof SKF or Timken Bearings. I have disassembled and cleaned the dryer already. I removed ALL the lint and the bounce dryer bar holder from it. I discovered that the element in Frigidaire Bearing Hitch Dryers is 4500W compared to the typical 5400W or the too high wattage 5600W heating element in Pile of crap GE Dryers. Maytag Halo of Heat dryers apparently have a 4800W Heating Element as stated by user Maytag85. The High-Limit thermostat is quite sensitive and I heard it shut off when I opened the door and didn't restart the dryer after 15 seconds. I saw a video of one with the door open and the High-Limit thermostat cut off the heating element after 15 seconds. For those of you that hate the Frigidaire bearing-hitch dryers. I agree on one thing that it gets HOT and FAST! I won't overload my machines and I shouldn't have problems with scorching/burning or poor washer performance. I removed all the lint from the shroud around the heating element. The washer has a noisy motor also which is what I would prefer because my long-lost GLTR1670AS1 had a noisy motor and honestly I love the sound. I linked a playlist of videos of another Frigidaire Gallery with a noisy motor. I love the spin cycle noise of when it ramps up from 500RPM to 950RPM. Hopefully my spider shaft isn't too damaged or else I will have to find a donor machine or a good used spider for not too expensive. $50 or less please (excluding shipping)
