After seeing the terrible results from John's (combo52) test load of very dirty towels, I was curious to find out if a longer cycle would produce better results. I spent the past two days wiping grime onto 48 bar mops (about 12" x 15" each) and two standard-size bath towels. Each towel was dampened, then wiped along door sills; on the siding of my house; on the kitchen and bathroom floors; around window and door frames; atop shelves in the garage; on outside windows; on the window well covers outside the house; on the vinyl A/C cover; over the outdoor patio table; and finally over three folding tables stored in the garage.
Not all the towels were as grimy as the ones shown, but all were soiled. Both the bath towels were quite heavily-soiled, as I knew from John's test that those would be the most challenging for the washer to clean. It was definitely a full-capacity load.
I used a full scoop of powdered Tide With Bleach HE; the Normal Cycle at the highest soil level (called Stain Treat) which clocked in at 89 minutes; the hot water setting (which, you know by now, is actually only lukewarm); the max water level (which, as John pointed out, is about 2/3 full); the standard 4 spray rinses; and an extra deep rinse, as the wash water was black as the ace of spades.[this post was last edited: 3/3/2013-17:08]
