launderess
Finally got around to putting a new pad and cover on the GM/Frigidaire ironer and it works a treat. Indeed find the results on par or even better then the Pfaff in some instances.
However as previously mentioned cannot get the roller to operate on "high". When control knob is turned to that setting the roller will not turn, other settings (low & press) are fine.
Am wondering if the problem is with a loose wire behind the switch, or the gears.
Suggestions, tips or information from a service manual would be greatly appreciated.
TIA
L.
TIA
L.
