I have started redoing my Jet-cone and have some question about the rollers and cleaning them?I downloaded the manual
and have watched the machine wash and it does work perfect.It tells you over and over not to oil things in there cause they
can get to the rollers and that I get but, it gives codes on oil to the agitate shaft and the other things that might need some.
I have always used Honda Automatic transmission fluid on machines that I have worked on it protects plastic and also is
the best lubricant I have seen when it comes to friction and also protects the rubber seals and things.It does say to use
porcelain cleaner on the steel rollers and then use lighter fluid on the urethane and the steel ones to clean that off.That does not tell me much cause there are so many
different types of cleaners out there.I would really appreciate any advice folks until I get another one cause I always have to
have two or three I don't want to ruin something..
