Frigimore washer and gas dryer
laundromat
Feb 9, 2010
4,209
Hilo, Hawaii
I found a pristine front loading Kenmore washer in Smith's junk pile yesterday.They're the set with square doors models 417 48102701 (washer) and 417 98042700 ( LP gas dryer). The washer works fine. I went and tweeted the water level on the washer. The dryer has some electronic issues. Any cycle you set comes on,the glowbar clicks even if the dial selector for temperature is set on air. After about a half minute,the dryer shuts down and all the temperature lights flash and beep. Then,it shuts down. There's no readout so no F5 or message saying what's wrong. I haven't hooked the gas yet but Airfluff shouldn't shouldn't cause it to go haywire like this. Any information on repair parts needed would be appreciated. Mahalo and Aloha!
Now, the washer took a dump. I removed the drain hose from the pump to see any debris since there's no button catcher,put it back and now it won't go into spin it just drains and the control light moves fringing spin to none then shuts off the board.WTF???
