Frigmore spin speed update
sudsmaster
Dec 23, 2004
15,034
SF Bay Area, California
Hi, I have a '98 Frigidaire Gallery front loader. Have had it for a couple years, but only just recently tested it out. I think the final spin speed could be faster. In reviewing an archived thread here about it, I saw mention of a simple internal wiring change that can shift the machine to a higher top spin speed.
Typing this post in hopes someone here can describe thr procedure or provide a link to such a description.
Thanks!
Oh gosh, that was a long time ago.....One does have to verify that the machine is only spinning at 650 RPMs.
If I remember correctly, there was a red wire on the controller that you moved from D to C or vise-versa. It would raise the final 50 second spin to 850 RPMs. Let me dig a bit and see if I can find it. It was a couple of machines ago.
Do You Feel Lucky?
You can in all probability get a wiring diagram from the Electrolux FTP site which would remove some of the risk. What's the actual model number of the machine?
Wiring Diagram & Parts List
are all that's available for the FWT445GES2. Here are the URLs. (URLs for FTP sites do not represent correctly in the provided box, so I will add them here in the text.)
Wiring Diagram:
ftp://ftp.electrolux-na.com/prodinfo_pdf/webster/131673500.pdf
Parts List:
ftp://ftp.electrolux-na.com/prodinfo_pdf/webster/95304333.pdf
