Garbage Disposals Terrible
Chetlaham
Mar 11, 2013
5,293
United States
Saw this article in my feed. I have to disagree with its 4 points but I could be wrong. I've put veggie stocks and egg shells plenty of times down the disposer no issue. I've never had to sharpen the disposer blades, deodorize, clean it, flush it or the like as the article claims. I don't feel it taxes infrastructure as plenty of water goes down the disposal for other reasons like washing up. I also don't see disposers wasting water either. I can stick things down a running disposer and still wash things in the sink. All in all I love my Insinkerator.
Only thing I could agree with is that when I had a super chintzy PM DC motor GE disposal it would get smelly for some reason, but that was the least of the worries when after a few months of being installed the insides would rust out. GE builder's grade never ceases amaze.
That aside, is there any truth here?
https://lifehacker.com/home/garbage-disposals-are-terrrible?utm_source=pocket-newtab-en-us
opinions
Hello Chetlaham,
First, if it was a Permanent Magnet motor, it wasn't built by GE. General Electric only used induction motors and series-wound motors in their disposals.
In the early eighties GE quit making disposals and like so many others, they allowed Anaheim Manufacturing to use their logo on their permanent magnet motor machines.
These Anaheim units carried many trade names on their labels, including GE and Waste King along with many other nomenclatures such as Franke, Bone Crusher, etc.
They were built for a price. Beneath the turntable, was a plastic base/liner in the collection chamber. Over time, this plastic developed scratches from abrasive food particles and this allowed remnant food particles to collect and develop odors. That was one common problem I had in the few Anaheim units I had. They all stunk, literally.
No GE employee ever touched an Anaheim Permanent magnet motor disposer. GE did get a royalty from Anaheim for the right to use their logo.
You are correct in your observations, that disposers (other than Anaheim's) are self cleaning and one of the most trouble free of all appliances.
I would hazard a guess that the residential disposer is probably the number one appliance for being the victim of old-wive's tales. You ask ten people what you can't put down a disposer and you will get ten different responses. Seems virtually everyone has their favorite item that a disposer can't handle. And in most cases you have ten erroneous answers.
There a few things a modern disorder cannot handle. I and possibly our member Volsboy seem to be the most liberal when it comes to what we put in a disposer. My philosophy is to keep all the organics I can out of the solid waste stream.
If it fits in the opening of the disposer/disposal, if it grinds and if the plumbing doesn't clog...I put it down there. Eggshells, as you have discovered, are nothing to grind up. Bones create abrasive particles that keep the interior of the disposer clean and as well as the interior of the pipes clean of wall build-up
Banana peals, watermelon rinds, fruit rinds and pits are all standard items that can easily be disposed of.
When someone does have a clogging issue, I have usually found it to be due to two things. Not running water for a ten or fifteen seconds after turning off the disposal. This makes sure wastes have time to be carried out to the main street line. Otherwise, turning off the water prematurely, may cause the wastes to settle out in the bottom of the internal house pipes and over time may build up. One day the pipes diameter gets small enough that fouw stops. Of course, whst was being ground up at the time, is given the blame. Hence the birth of a new wives-tale. It was not the fault of what was being ground up, but the fault of the homeowner for not doing what all disposer manufacturers tell you, let water run for a short period after grinding.
The second most common mistake, I see is improper mounting/installation of the disposal itself. Instead of having the discharge in the back, through a separate dedicated trap and into the drain line, so many people use one of the disposer installation tubes.
They mount the disposal on one sink side and turn the disposer sideways and shoot the discharge directly into the other sink's drain line. To do this one has to use the homeowner installation tube available at the big box home stores. If you look If you look in the tube you will see a baffle at the disposal's entrance coupling. It forces the disposal's waste discharge to make an instant ninety degree turn in only half the diameter of the pipe. A perfect clog point.
Fibrous wastes can collect here. Another wives-take born, that you can't grind fibrous wastes. Yes you can, you just have to have the intellect to not force it to take an instant ninety degree turn in only half the diameter of the pipe.
These disposer installation pipes were born to allow consumers to have an easy way to go home and put in a disposer themselves. It doesn't take too much of an I. Q. To install a disposer correctly, with a dedicated trap and a wye fitting to discharge in the full diameter of the pipe with a effortless 45 angle flow.
I would hazard a guess that most people believe these wives-tales without questioning them or without scientic investigation, to see if they are true, through experimentation. Most people believe what they hear without questioning or it or gathering their own experential data through experimentation.
A residential garbage disposer is one of the most ecologically sound of all home appliances. Not only does it keep organics out of the food waste stream, where they contribute to the ovrtloading of our sanitary landfills, but organics are responsible for the methane production that occurs within the landfill.
Organics in trash cans, wastes collection systems and the landfill are contributing to the growth and reproduction of vermin (maggots, rodents, etc.) feeding on them.
We had a meeting with our city's utility manager a few years back, and I asked her about the impact of the residential disposer on the city's waste treatment facility. As far as the extra load applied to it, she said it was almost negligible. As far as the impact on the operation, she said the organics contribute to the anaerobic bacterial growth and helping the system. She said overall, the effect of the disposers on the system, was actually slightly beneficial.
I can't think of too many appliances, more reliable than a disposal, more conducive to cleanliness and more proactive in preventing methane releases, reducing loads in the solid waste stream and helping to prevent the spread of diseases by eliminating food sources for vermin.
The residential garbage disposal can cope with just about all food wastes, the only thing it can't cope with is human ignorance.
Beautifully written, a breath of fresh air, this is what I wanted to read. Thank you!
I had no idea those GE disposers were made by Anaheim. Or why they always smelled so bad. Now I finally have an answer as to why. They had a square full wave bridge rectifier in the base and thick magnets which seemed quite strong to me. The rest however did not last long.
I love how much disposer cut down on waste, and of course it makes the garbage bin less of an odor producer. It truly feels like magic- stuff it down and its gone for good.
Haier
Bob, Yes. GE quit manufacturing disposals in the early eighties, and at that point Anaheim began putting the GE logo on their own units. So, as you say, the "cheapening" began long before Haier purchased GE appliances in June, 2016.
Even when Anaheim got the rights for the series-wound motor design, from GE, in the latter eighties, they "cheapened" it up as well with a physically smaller motor, that also had reduced current (amperage) draw.
[this post was last edited: 8/1/2024-09:20]
Well in the case of discarding a bone I couldn’t get most of the remaining meat off of, and sucking out the seemingly raw or just uncooked or undercooked center of, it wanted to use my garbage disposal for it…
I think putting it in there jammed the disposal and I felt the reset button under the unit but felt as long as I was on the floor down there I thought I would also use the hex key and give it at least a half-turn just to presumably grind up the rest of that bone…
Which I think it did…
— Dave
Dave, I just want to say that is mouth water. Looks perfect and delicious!  10/10 color, 10/10 presentation, 10/10 serving, 10/10 style and 10/10 (most likely) taste. I love what you do when cooking.
Thank you appnut and chet...
There is another ham, more black-eyed peas and leftover okra and Lima beans to make that again...
We now return to our thread of stuff that goes in our garbage disposal...
-- Dave
well right now my garbage disposal is clogged...
even tried using the hex-key wondering whether it should turn clockwise, or counter-clockwise...
and is it okay to use that key down there while the disposal is on?
not even some drain opener a plumber gave me or either my tall plunger or short plunger is even helping...
-- dave
-- dave
Could be the T connection or the trap. A lot of cheap pre-made DIY traps can easily get clogged by things like cellary. Might have to take things apart underneath the sink depending on where the clog is.
yes I located the trap in the basement under the sink...
should I dare myself if I even have a proper wrench to un-do it?
seems like I should still call a plumber...
-- Dave
I give everyone this blanket statement: If you're hesitant or unsure- call a trusted professional. You already know enough to question your endeavor which is a sign of great intelligence. Some folks are so clueless they begin an undertaking without having the general insight into the knowledge they lack.
DIY only works if you 100% know what you're doing and have enough experience to back it up. Not to invalidate an individual with your brains, but we all have our strengths and yet to be mastered skills.
If you're going to do it yourself have a bucket and wet vac- be prepared to potentially catch a lot of dirty water.
When I movd into my house in 2005, the kitchen sink had an Insinkerator 3/4HP "333 PRO SS" disposal which was installed in 2000.- now 25 years old and going strong.
I never had an issue with the machine., never any clogs.
Sometimes, I run the hot water for a few minutes before disposing stuff to soften and loosen any "down the pipe" grease residue that will keep the plumbing free-running.
And like the member reactor has said, I've put all that stuff down the disposal.
Yeah, chicken bones, fruit seeds, shells, etc., can be noisy, but other than that no problem.
And I run the faucet water for a full minute or two after disposing, to make sure the crap gets to the street main.
Sometimes even a pot of water dumped down the drain is cheap insurance.
I figure this picture might belong better in the vintage appliance ads section.
I found it in the kitchen pantry one day - probably from the previous homeowner.
It's the front page of the owner's manual for Insinkerator's "77" model of 1964.
