Gas 1950's Westinghouse Dryer - $40 (Bath)
Probably about as fast as "Warm" setting on the Wards gas dryer by Norge that used a 1000 watt electric element to provide heat on the "Warm" setting. Of course, with the Norge's airflow, it might have been faster.
Dryer
That Dryer is about 40 miles from me, not interested in it but if someone is, I could pick it up until they could arrange for shipping Jim
So were WH dryers of this era manufactured to switch between using 120/220 volt by changing the wiring connections inside? If the dryer is currently set up for 120 usage is a simple connection change internally all that's necessary to use it on 220? Or did they manufacture two different lines of dryers: 120 & 220 volt?
