Gas Air Conditioning?
It's true
Yes, here in Palm Springs we once in a while find the monstrosity condenser unit on properties that have been held by matriarch families and sold as estate or trust held properties that have been neglected or abandoned for years. I believe the transfer of heat to cool and cool to heat by natural gas is the same ingenuity that was used for refrigerators that were fired with kerosene.
I’ve always wondered about how gas air conditioning when I saw that one advertisement awhile back. I guess they were trying to figure out how to put natural gas to use but natural gas works better for heating and drying laundry but not so well for cooling.
When we used to visit South America in the 90's we stayed in a lot of condo resorts and most to all units had gas a/c units. Most were in a large closet and you could see the gas flames inside the unit. It was warmer in the closet but the condo cooled nicely. It was a central a/c with vents in all the rooms. I guess with these you have no outside compressors nor all the piping that goes in and outside through the walls. Others I have seen have the cooling units outside with a small metal chimney on them, with the input and output vents connected to the outside units.
Jon
Everyone thought that they would be cheaper to run because gas costs less than electricity, but that was not the case. In addition to the gas burner, they had electric pumps to move the brine solution and fans and expensive service calls. They also had little reserve capacity. Friends had a gas system and went away one summer for a few weeks. Right after they left the brine solution leaked out and the gas burner ran full blast for the entire period. They came back to a very hot house with no way of cooling it down and a big gas bill. The put in an efficient electric system and their electric bills were less than with the gas system.
Growing up, my next door neighbor managed the local Peoples Natural Gas office. Their house was a showcase of sorts for natural gas products. They had a gas incinerator in the garage, gas central air conditioning, a gas refrigerator and a dishwasher that used gas to the water. This would have been around 1967. The gas fridge was replaced with a conventional one within a couple of years. The dishwasher was replaced with a Maytag reverse-rack. The AC was replaced with a standard non-gas unit the year I went to college ('77). They had to stop using the incinerator when local burn laws were changed in the mid-70s.
Can you imagine calling a company "Peoples Natural Gas"? I chuckled every month when the bill arrived.
gas refrigeration works OK when you don't have other options, but it is horribly inefficient. I mean inefficient in the true meaning of the word, of comparing energy used to watts of cooling provided. Not whether it works well, that isn't efficiency.
Compare my current electric fridge with its gas equivalent:
My fridge is a cheap Haier 2 door 215 litre standard electric fridge. It is rated to use 325 kwh a year, that is less than 1 kwh a day. (I have monitored its consumption myself and it actually averages about half of that - it generally uses about 1/2 a kwh per day.) It is a few years old now, a newer fridge would use even less.
The equivalent size in the Dometic gas fridge range is the RUA8408 and that is rated to use 5.8 kwh in 24 hours. that is six times the energy consumed by the electric fridge.
They are also expensive to manufacture - my Haier cost $298, the equivalent Dometic 3-way gas fridge costs about $3000.
we previously had a smaller 150 litre gas fridge and a small solar power system. We worked out it was cheaper to buy the electric fridge and upgrade our solar to give us the extra electricity we needed to run it, than it was to buy the gas fridge, even without factoring in the gas consumption of the new fridge. Plus the extra solar panels give us more power to use for other things, too.
As I've previously stated in the forum, the house my parents bought September 1961 was an all gas house, complete with gas central air. And there was not a 240V line for an electric dryer.
My dad told me that when the Astrodome was designed in 1962 and completed in late 1964, it had both gas and electric a/c. The logic was gas was cheaper to do the normal maintenance of cooling but electric was turned on to bring the inside temp down quickly in preparation for game crowds.
Gas clothes drying is more efficient and cheaper to run than electric gas drying. That is, if you have natural gas piped into the home. Same for natural gas home heating.
I remember once learning about how a gas flame can be used to power a refrigerator, but have banished that from my memory banks. I'm not surprised however that it's less efficient than electric refrigeration. I suppose it makes sense if one lives in the wilderness with no electric service but a big LPG tank out by the side of the cabin. Even then, with the advent of more efficient solar electric panels and storage batteries, electric may be a better solution there, as well.
The gas company for the city of Chicago is called Peoples Gas...
There was a This Old House season from around 1991 where they were in Tucson and they went with a natural gas chiller to cool the house. I didn't know it had been a thing even that recent.
In 1967, My Dad's restaurant had a Major Renovation.
He replaced a 1950's Carrier Stand up Console (with a water tower on the roof) with Bryant Gas Air.
This was nothing but problems right out of the gate. The pump failed continuously. We averaged one pump per year.
However, when it did work, it was like Antartica in the bar. When they first got it running they brought the bar down to 59 degrees on a Hot July day.
He sold the place in 1975 and as far as I know it was still there for a bit after the sale.
<span style="font-size: 14pt; color: #008000;">According to what I've read, half of Dinah Shore's ashes are interned in Memorial Park Cemetery in Culver City and the other half is down the street from me in Forest Lawn in Cathedral City. I guess I could take a walk down there and ask her how she liked her gas air conditioning but I'd probably only get half the story. Besides, it was 121 degrees next-door in Palm Springs last Sunday. Not exactly "walking" weather. Her home has been for sale twice since I've lived here. I'm sure the gas air conditioning is long gone.</span>
