gas dryer air shutter adjustment - can't see flame ???
rickster
Feb 7, 2015
Frigidaire gas dryer model crgf342as2
converted from NG to LP via PCK2003 kit
OK so I need to adjust the air shutter but I can't see the flame with the front panel on.
I need the front panel on to support the drum and this will only burn when turning.
How do I view the flame or how do I make it burn without the front panel?
Thanx - very frustrated over what I assume is simple.
/Rick
on some there were markings as to where to set it for NG, and LP...
just line up the marks, and tighten the set screw.....
but also had others that no adjustment was required....your mileage may vary
but true, that was my only complaint with these type of set-ups.....theres not even a view port or access panel...
