Gas Powered GE Washer for free
thomasortega
May 6, 2008
3,734
El Pueblo de Nuestra Señora de Los Angeles de Por
Does it use regular for delicates, premium for normal and V-power for Heavy duty cycle?
How many cycles per gallon? Would it pass a smog test? Does it come with the Pink Slip? If it stops working, can I call AAA to fix it? Will it be fixed in place or it has to be towed? What about the oil changes. Can I do it at Jiffy Lube? Why it's in the curb? Won't you get a ticket if it's still there on street sweeping day? WHat detergent should I use? Can I use regular Castrol?
https://losangeles.craigslist.org/sgv/zip/d/monrovia-free-ge-washing-machine/7211215439.html
CURB ALERT - FREE - NOT WORKING gas powered
text if you want to know if its still available curb side.
626 SEVEN 5 7 2 0 5 THREE
do NOT contact me with unsolicited services or offers
"How many cycles per gallon?"
Completely dependent on the user and their drying habits.
"Would it pass a smog test?"
No smog required in 49 states.
Must be equipped with a CARB compliant catalytic converter, pass visual inspection and 5 gas dynamometer tests in the state of California. Any failure will automatically tag dryer as a gross polluter. If your dryer has a failed smog test and applicant meets the low income requirement applicant may be eligible for up to $100 towards repairs to attempt to make dryer pass smog test. If your dryer is older than 1995 and passed smog, you may be eligible for $300 dryer retirement payout.
Results electronically sent to the DMV.
"Does it come with the Pink Slip"
Buyer may choose any currently available color of receipt during purchasing period.
"If it stops working, can I call AAA to fix it?"
AAA will only tow your dryer to the nearest repair facility within 10 miles. Additional mileage will be charged at 5 dollars per mile.
"What about the oil changes. Can I do it at Jiffy Lube?"
Oil is good for the life of your dryer. Any signs of tampering will void warranty.
"Will you get a ticket if it's still there on street sweeping day?"
All dryers will be towed at the expense of the owner if on the curb during sweep day or 72 consecutive hours without moving.
"What detergent should I use? Can I use regular Castrol?"
A good quality detergent is recommended for optimal use.
It's a washer, not a dryer.
Yeah, I know but I couldn't think of any decent answers on the fly for a washer so I used a dryer and even weaved the washer in there. I hope nobody here is using detergent in their dryer.
