passatdoc
Hi folks
This morning I discovered some water had leaked out of my seven year old, 40 gallon gas Bradford White water heater. The heater sits in a drain pan atop a pedestal in the garage. I found about 35-50 ml of water on the garage floor. A quick check showed the drip pan was dry, and the drain pipe leading to the temperature/pressure relief valve was wet.
The heat appears to give excellent amounts of hot water, there is no sediment in the lines and it isn't making any funny noises.
I went to Lowes today (unrelated reason) and, while there, asked the salesperson in the plumbing department about the leak. I should add that we had unseasonably cold weather in California, with rain/hail/thunder, due to a storm from Alaska (no, Sarah Palin was not in town...). Temperatures were 15 F/10 C lower than normal, and it was a quick drop.
The salesman said that if the heater appears to be working, in terms of producing plenty of hot water, and if there is not leak from the tank itself (pan is bone dry), it could be the result of the sudden weather change. He said if the drainage disappears once the weather warms up, it may be just due to weather. He said in the worst case scenario that the TPR valve might need to be replaced, but that the heater itself is most likely ok.
Questions:
1. Is this true? Can a sudden temperature drop (garage is unheated/uninsulated, and we were in the 70s on Sunday, now in the 50s) actually cause "normal" leakage from the TPR valve?
2. If the leakage continues, can an average consumer replace a TPR valve? Or is this something only a skilled plumber should attempt?
Thanks in advance for your answers,
Jim
Questions:
Jim
