GE 80s GSD 2800 dishwashers etc.
This was a fairly remarkable achievement for GE these top-of-the-line machines with food filtering in multi or bar were the first dishwashers GE ever built that really worked well.
Like all dishwashers, they developed problems as Matt recounts, the black rubber, boot, and hoses that were used on these dishwashers whirlpool other companies had problems as well would start to breakdown from the chlorinated phosphate detergents that were used at the time And you would get little black specs on things.
The multi orbit wash arm on the GE dishwashers would have trouble turning as it started to wear out, the worst thing about these GE dishwashers was limited loading in the lower rack and the lack of cleaning in the corners of the upper rack so GE changed the design in the 90s. And added a real top wash arm.
GE put a lot of development and engineering into this model so it had relatively few problems for quite a few years. The worst thing they did is they used the same cheap motor they used in their $59 dishwashers in these top-of-the-line machines with no improvement so you had a very noisy inefficient motor where the seals went bad both for the trip valve and for the main shaft seal eventually, the good thing was you could replace the whole assembly, but you had to remove the machine and some installations to do so sometimes you could get it in from underneath when it was installed.
John L
