I have GE P7 double ovens the same color as the range. Does your range have a window in the door? My ovens do and I can't lock the door until I raise the shield to cover the window. Once this is done then you push and hold the latch release and move the lever to lock to lock the door shut. After that you set the start and stop times. Nothing will happen until you get the stop time set. Once it has gone through the cleaning cycle. it won't let you unlock the door until its cooled down. Also if your lucky enough that your oven racks haven't been run through the cleaning cycle and are still nice and bright I would make sure they come out of the oven before you start.
I will look for the instructions for my ovens and post them if you would like. I haven't looked for them in quite awhile but I know I still have them.
