GE Activators
VERY nice, Baja. question for the GE experts, WHICH of these "activators" was best at turning over the heaviest loads?
Hi David, to answer your question, the 18 lb. Ramp Activator will handle the biggest load out of them all, of course, but on the standard-capacity machines, the Ramp Activators are still the best choice. The "dip-roll" action is really what makes these machines have such a good working capacity, and it also makes for a lot of splash-drama on lower water levels. A considerable amount of water will leave the machine during the wash cycle! The straight-vane Activators are fun to watch as well and really thrash the load around, but don't hold nearly as much as their ramped cousins.
Nice renderings, Baja...
Note that the 1957 P series were the same as the '58's you have depicted including the pink cap.
I know you're into GE's, but it would be great to have some renderings for other brands as well.... say maybe early Norge.
Activator Cap Colors
Our OLD GE 1958 had the pink-colored control panel, and the pink activator cap. Our machine was white. I DO remember that sometimes the white machines had either pink, turquoise, or yellow caps AND matching control panels with the silver accents, either with the white OR corresponding color cabinets. Am I correct??? Also, our machine's tub used to spin as it agitated-I think the stop wasn't working. It never indexed when we owned it from Dec. 1962 to February 1968, when we got our Hamilton W600. OOH-I completely forgot! We oned a 1954 Caloric Gas clothes dryer when we had the GE washer!!! How's that for a rare item? I still have the operating brochures and replacement lint-filter "stocking"!
Thank you Westy! The last white activator was supposed to be the one you have in the pic. I will make that change post-haste. Your pic reminded me that the ribs go sideways, not parallel to the vanes.
GE Activators
Ken,
Thanks so much for posting the Activator pics. It is so great to see the whole series of the lifecycle from a specific brand.
Peter
Baja, FYI, mom had a filter flo that was either a 1977 or 1978 and it had the white ramped activator so they must have been phased in before 1981. Hope this helps!
Many thanks for the excellent artwork. The curved ramp Activators gave the load agitation similar to that of the Easy Spiralator because the fins did not square off to become perpendicular to the skirt at the base like a Rotoswirl which turned over the load with less circular motion around the tub. The old Easy ads showed the path of around and down. I do not know what GE was trying to accomplish with the straight vane Activators, but I never thought that they did much of a job of turning over a load when I watched. Maybe they did not have to. I guess they cleaned OK.
I agree with you about the staight vaned activators. They were very pretty and they did a good job of holding up the mini-basket, but all they did with a Bob-load was move the clothes back and forth. I remember the ramped activator on our old GE V-12 could get an oversized load rolling over in no time.
The straight-vaned activator in the solid tub models did a decent job as well, but I think that was because, as with GM Frigidaires, the proportions of the washbasket to the size of the activators made for good rollover.
Early GE Activators
Butcha know something? In tests by CU, the old GE Activator machines only rated Fair at cleaning. They did not have really strong agitation like the spiral ramp design. With the old Activator, GE ads used to talk about the three zones of Activation, Brisk at the bottom, gentle at the top, moderate in the middle and the load passes through all three. That's nice, but how often and how fast?
Not to mention the last large capacity ramp agitator that was only the standard capacity ramp agitator with an attachment extention on the top.
I'm guessing that the straight vaned activator/agitator made for a larger tub measurement since it hogged-up less space.
The "mine is bigger than yours" game went on for decades.
Here in this area. washers in the 70's were basically WP/KM due to size and features and dryers were GE due to porcelain tub and price. That combination I'd say was the "most-seen"
I guess that people didn't (want to ) realize that if one rams too much in a dryer, the clothing wrinkles excessively.
76 GE activator
HI
My first new washer was the 1976 heavy dutey 18 and it had the straight vain agatitor in it and tuquorize noless and the large filter pan and the mini basket. I just loved that washer and always had very clean clothes. it did a great job at roll over but I had to use low suds detergent. I had that washer until 1998 when I sold my house in the East. it was sort of on its last legs by then but it still washed well. When I moved hear to CA I got the ramp one and I only kept it for six monthes.it was a rebuilt one. I absoultely hated it.it tor clothes pulled off buttons and socks kept going over the top of the tub and jamming the pump even when used on small load. the shop that I bought it from took it back and I was able to choose another one. I choose a beautiful set of Kenmore 800 series for the home I had at that time. In my present home I have the Frigidaire front load washer and dryer for two years now and live them.
WCD63
HMMMMM I am wondering if the drain-hose was ostructed/constricted or if the pump had some broken impeller teeth. Sounds to me like maybe the machine got up to too-high a spin speed before enough water was evacuated.
Mom had a 1959 GE FF and our little socks went over the inner tub and would clog the pump inlet a few times somehow. It had the wire clothes guard. I assume small socks could fit through it. She replaced it with a 1978 GE FF and that never happened with that machine. It had the plastic clothes retaining guard which had smaller openings.
