GE Adora Front load washer
captainmoody
May 22, 2006
348
I saved several GE front load washers from the crusher (for now anyway) at my local scrap yard. Several were GE "Adora" front load units that are a little over a year old!
They were missing the data tags, so I am assuming they were scrapped by an appliance store. (the guy at the yard said Lowe's)
From what I can see, they are Chinese made by a company called "Little Swan" Are they considered pure junk? From what I was told, they fill but wont agitate, and haven't tried checking them out yet.
If they are front loading machines, they would rotate vs agitate. IMHO you need an agitator to agitate, and FL machines don't have one.
The only thing I have heard about the GE Adora FL machines is that they are relatively cheaply made and have very long cycle times. But there is very little information about them out there.
Given their relative youth, I would guess that they may have control board issues - either motor or main or both.
Initially I thought that GE had hit a home run with their Adora series. 3.6+ cu ft capacity, internal heater, true horizontal drum, there wasn't much to dislike on first gander.
But since then I've not heard all that glowing feedback from owners, coupled with lousy reviews in CR etc. Seems like someone at GE initially had the right idea, but someone at GE cut too many corners getting there.
I had those machines in an apartment I used to live in. They are the same as Frigidaire front loaders (The FriGEmore) and should perform like the Frigidaire. They don't hold as much as the Adora (strange name for a washer) and the drain pump roars but they do seem to work well and are reasonably reliable, although the bears may give out after 4-5 years. Also, the matching dryer is small and tends to run hot.
GE is now marketing the 3.5 size Frigidaire front loader under the GE label. A tad smaller than the Adora, but not by much. A very good, reliable front loader at a reasonable price. As mentioned, the dryer isn't huge, but certainly is adequate. The good thing is that these have the same footprint as the smaller capacity 3.1 sized front loaders and will fit almost any stacking/installation situation, where the Adoras may not as they have bigger and deeper cabinets.
Well, I partially checked out the "Adora" tonight. I wasn't ready to drag it over to the laundry tub and hook it up to water yet, so I tried a small bit of air pressure to the fill valve to get it to agitate, rotate, whatever..
Anyhow, it did rotate forward and backward, so it is doing that much ok. Didn't seem to spin though, but the drain pump is working so I may just hook it up to water tomorrow.
did anyone else but me
ultimately reject these machines
because they are made in china
and chinese-made equipment are thought
to have lower durability standards
i know i did
and i'm wondering if
my initial bias was actually correct
Yep, I avoided the Adora because of concerns about durability. Initially I thought the design presented well enough; no blatant shortcomings a la the Frigidaire Affinty dryer door hinge. But it bugged me that GE’s marketing approach was to sell a front loader that was priced noticeably less than its competition. If one cost-saving measure was to have the units built in China, I figured they could have skimped on parts quality, too. Wishing to avoid purchasing potential garbage, I chose something else with a proven decent reputation.
Ugh!
My folks bought this set. While there is little that strikes me as being too horrifying, there is nothing about them that impresses me, even slightly. The washer's cycles take FOREVER, even by front loader standards. The doors and controls also feel cheap. The dryer has the worst lint filter I have ever used. It's almost like they want you to leave it alone, it is so hard to clean. If I had to choose between this and a classic MAytag, it's Center-Dial all the way!
GE, you used to be so good, bring back the FF and be good again!
Dave
Re: Bring back the FilterFlows
Volvoguy87, Thank you for saying it, it is also my wish that G.E. would bring back the FilterFlows instead of the Shit that there making nowadays. My question is why do the manufactures do this when they have one of the best washers on the market and then go and switch it out or try to "improve them" when they already had a damn good washer that was reliable and washed well? Can someone answer this for me as I would really like to know? Thanks Danf.
Home Depot was carrying the Adora series washers/dryers, refrigerators, and ranges. They seemed to be at the low end of the price scale, but with a trendy-looking exterior. I guess they would fall under the "disposable" appliance category.
As manufacturing ideas (or lack of them) are cyclical, perhaps a filter-flo once again in GE's future. You would think that appliance manufacturers would latch on to an idea that is unique and effective rather than jump on board the banal bandwagon with the others.
I was checking out prices around here this morning, and noted that, while the Frigidaire models are being very aggressively discounted, in the five hundred-ish range, most of the retailers are still selling the Adora over eight hundred....peculiar, given it doesn't seem to be moving well.
Initially, the GE appealed to me price-wise, versus comparable Whirlpool, Sears, etc. models, because it had an internal heater.
And then, I looked at it, and got that queasy feeling you get whenever you look at GE washers nowadays....it was sort of like a bad vibe.
Thank you
I had no idea that this was the Adora that everyone was talking about. i will have to look closer at them. As far as bringing back the Filter flow, i could not agree more!!If it is not broke,don't break it! What happened to pride in a product well made? Is it truely a race to see who can make the most money? Or is loyalty not as important as it once was? For example, i am in the process of getting something rebuilt for me in Florida, for the reason that they just do not build them that good anymore. I don't care to go and buy a new one,it is just going to break on me.This coming from a guy that has a rotary phone next to his bed,50+ years old and it still works. I do know of a few laundries in Portland that still have Filter flo machines.I always get excited when I see them still in operation. The cheap,flimsy, and well, tuperware GEs just do not cut it.------Bring back the Filter Flo!!!!!!!!!!!!!!!!!!!!!!!!!
The Filter-Flo's were huge water hogs. GE didn't change their design very much when they went from the solid tub to the perforated tub. So the FF machines fill the fixed and anchored outer tub, while the perf tub had plenty of room to rock about in the cavernous space. Other manufactures made the outer and perf tubs in one moveable unit, so that there was usually an inch or less space between the outer and perf tubs. With the GE, there is 2-4 inches between the outer and perf tubs, with even more room at the bottom. HUGE water hogs!!!
Yeah, but no chance of suds lock... lol...
I'll have to take another look at my '78 GE. As I recall the outer tub is cylindrical. I thought it was suspended in some way, but now I'm not sure.
When I was doing research prior to purchasing my Duet pair, I visited another appliance blog site and was advised by someone who I believe is the moderator, a parts/repair guy named Jake, to go with the Adora pair. He said they were made in China but still recommended them. As I cruised that site and read postings on other topics, I saw this same guy chiming in and quickly recommending replacing parts, especially when it came to ice makers on refrigerators, rather than making a simple repair to the existing mechanism. He was like a broken record advising many people to replace this same part. I did the math and decided that this guy's advice had a self-serving slant and haven't bothered with that site since. I mean, who in his right mind would recommend a GE washer to anyone?
I agree with Scott. The fact that these machines are made in China is reason enough to boycott them.
